View Poll Results: Am I safe w/ 42's w/ my 2.8?
Yes. 42's should be just fine w/ your 2.8
13
52.00%
No.
12
48.00%
Voters: 25. You may not vote on this poll
Been gone for awhile, but I know this question has probably been asked MANY times.
What's the scoop w/ stage 2 and the 2.8 and 42lb injectors? Are people having significant problems with it? Is the majority having no problems? I've been gone for to long to see or hear problems w/ it. I'm trying to stay under warranty and don't want to get screwed or pay more than I need to. Th
2.8 is really the limit of how far you should go with 42's. Some folks have been running around with the setup with no problems.
Recently the trend seems to be that in the upper RPM ranges the injector duty cycle is getting close to or going over 100%... very bad. Ideally you want the IDC to be around 80% max... or you risk having your injectors lock open.
Personally... I'm not gonna go that far. 2.9 with the 42's is as far as I'm going.
you should be fine i think "Intense is running that and their getting 263whp and 247torque with header,downpipe and pcm reprogram,stage 2 belt.
but for a extra 20 bucks i guess u could go 60, just in case u want to go smaller pulley lata down the road
Last edited by DressBoyBlues; 03-02-2007 at 03:57 PM. Reason: Automerged Doublepost
If you're worried about warranty at all... go GM Stage two... toss on a 2.9... you'll be fine.
Agreed.....people just throw out universal rules that don't apply to eveyone.
The 2.8 and 42 argument has many factors that people tend to ignore like temperature, altitude and if you ever run your car over 6000rpm, which some people don't....
Being real close to sea level and at about 50 degrees over 6200 rpm the 42's are over 100% duty cycle, but i rarely run my car that far, most of the time i stay under 4K. Someone going to chime in and tell me that I can't run my 2.8 safely for my situation???
So for everyone telling him no you can't or yes you can SHUT UP, its not that simple.....
1 Post
Ok some actual dyno performance and experience.
Last weekend, i dyno'd my car at 244whp and 220lb torque. Im running GM stage 2, Injen CAI, Ark catback exhaust, and a 2.8" pulley.
Before 6grand, my AF was where it should be, After 6 grand, it ended up going crazy and running lean as ****. I actually got a lean misfire, which is known to take out pistons.
Needless to say, my car barely goes over 5k now. Until I get it tuned, it will not be seeing 6k and it won't see much boost, if any at all either. Gas Mileage FTW!!
well i guess ill have to go with the 60's then b/c u guys are smarter then me so ya and ill have to rethink the whole intense pcm i might just have to follow the trend and get the hptuner....
