Belt Size
Old Oct 21, 2010 | 11:27 PM
insylem's Avatar
Question Belt Size
I baught mine used, pre-modded with a ZZP 2.85" Pully,
What's the stock Tensioner pully size?
How can I tell if I need a stock belt, or a
Stage 2 belt?
Old Oct 22, 2010 | 01:14 AM
Reaper06's Avatar
Well first off your about 4 pulley sizes away from the stock press on pulley that came on the blower. With your setup I assume it allready has the gm stg 2 belt. Stock belt wont work unless you run the zzp 3inch tensioner I think. Stock pulley tensioner is 2.5. Regardless if you need a new belt get a gm stg 2 belt, if your haveing a belt slip issues with the new belt buy the $10.00 zzp tensioner pulley and that will fix that. I havent had a issue with the belt on my 2.7 so take it for what its worth..
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
cw383
Sep 30, 2015 12:41 AM
