belt slipping
belt slipping
so we put a stage kit on my buddys car with a 2.8 pulley and ever since then the belt has been slipping at like 6000 rpm anyone know why or how to fix we tried tightening the belt tried new tensioner nothing worked
yea put smaller belt and aftermarket tensioner pretty sure its belt slippage cuz boost drops to like 5 psi at 6000and above
anyone got any suggestion on what to do
Last edited by shrekyshrek; Oct 31, 2008 at 01:09 PM. Reason: Automerged Doublepost
I bought my car used, and i did not know that the zzp tensioner was on, so when i ported my SC the tensioner was missing the notch for the 15mm wrench, and i was all wtf? so i took off sc and loosened the tension on it to get it off, but getting it back on was a no go. So i bought the stock tensioner and sure enough peice of cake with the proper leverage. I may just dremel a notch in the zzp one to get it on, i think im getting belt slip as well
You can try belt dressing they sell it in walmart for like 2 bucks. Shouldn't slip with a 2.8 unless you fucked the tensioner which you may have done?!?
