Belt Squeak Problem
Old Oct 8, 2010 | 04:17 AM
spitefulxcheerio's Avatar
Belt Squeak Problem
I'm running a 2.6" pulley with a zzp over sized tensioner pulley. When I accelerate and hit about 2500 rpms, I hear belt noise. A steadily increasing chirp would best describe it and the noise happens both when in boost and not. It's been rather cold here at night while its doing it (40* and such in Northern Florida) and I dont know if that has anything to do with it but just in case.
Does anyone have any idea what it could be? Pulley bolts? Does the tensioner have a certain tq spec that I exceeded? Or maybe the tensioner is too big/small and I need an adjustable tensioner? Any advice helps!
Old Oct 8, 2010 | 10:38 AM
mrbelvedere's Avatar
make sure the belt is on all the pullies correctly mine was off 1 rib on the ac pump and it made noise
Old Oct 8, 2010 | 10:47 AM
ill check that. thank you
Old Oct 8, 2010 | 12:02 PM
checked all the pullies and it appears that the belt is on fine. The squeak will be there when I cold start it but will eventually go awhile after idling for 5 minutes but then it'll squeak if I give it gas
Could it be the bearing on the tensioner?
edit: also, I've gone wide open throttle 2nd, 3rd and 4th consecutively and the belt didnt slip
Old Oct 8, 2010 | 02:01 PM
could be that or the idler or the alternaor making noise
Old Oct 8, 2010 | 09:18 PM
Dainslaif's Avatar
It's probably the tensioner pulley. Mine's been chirping for years, never caused a problem, just loud/obnoxious. You'd have to replace the thing to get rid of it. Not worth the hassle imo.
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
