Belt Tensioner
Belt Tensioner
So I took my s/c off today mainly to prep myself for installing the dual pass endplate, just so I knew what I was in for and stuff (first time taking it off). Everything was pretty cut and simple till i got to that damn tensioner. The taking it off was easy, I weasled it off blah blah, putting it back on was a totally different story. After some blood on the pulleys and a bit of scruffing up the idler, it got on... Is there a better way than just an open end 15mm? I could've just said **** this car today.
yea lossemeong that thing is a pita
There is a company that makes a tool that makesbit easier pulleyboys makes it if I remember correctly
You could also get am adjustable tensioner from zzp or ca which makes it a bit easier IMO
yeah ralli i was just taking the belt off.
i emailed zzp about their tensioner to see if they could mail me instructions and more info.
looked into that pulleyboys thing and 90 bucks is kinda ridiculous, atleast the 100zzp thing i can reuse if i drop pulleys, right? Im guessing its a direct replacement of the stock tensioner?
I just felt like i was rounding the stock piece off everytime the damn wrench would slip
I don't even play with the tensioner. I just loop the belt around the s/c, and then push the supercharger down on the manifold and start putting the screws in. Bingo, easy as ****.
Hmm that's a good idea also...i'd be kinda worried about knocking something off or bending a mounting stud or the gasket though lol
i havent tryed ralliartist method but whe i hammer the 14mm on mine i was able to pull the tensioner with one hand and use the other hand for the belt to hell with that 15 slip off junk
I just changed my tensioner pulley and belt and all that blah blah...
I found it easiest to use a small pair of vice grips...
wasn't easy pushing the tensioner down but they stayed in place and was nicer then useing the 15mm.
oh and gloves...i learned that from hurting my hand on the thing from the pressure I was applying.
