best of the best with lsj's inside plz
Old Jun 22, 2010 | 08:21 PM
stew_pidaso59's Avatar
Ok so the whole story is I got ottp stage 1 bout a year ago. also added vibrant header and high flow magnaflow cat with a 2.5 mandrel bent cat back with 18"resonator and magnaflow muffler. I went with canned tune from ottp for a while and then I added meth inj. and had zach do a custom tune on it. within a couple weeks of the meth and the tune I starting collecting black soot on my rear bumper near the exhaust. shortly after than i got a cel 0420 i believe that comes up cat problem. well now at 2500 rpms on level ground in 5the gear my vaccum is about 8 to 10 negative. my boost often hits 18 or 18.5 in wot.
So I guess my questions are as follows:
Do I take the dp off and ram a crow bar down it and get as much of the cat cleaned out?
Is the cat for sure clogged?
Do I need a retune due the soot building up on my rear bumper? Is it running to rich or what?
Then I got to thinking that if all that soot is makin it to the bumper what do my plugs look like? should i replace those too?
Any help from all of you that are waaaay smarter than me would be appreciated..
Thanks
Tim
Old Jun 22, 2010 | 08:27 PM
SlowBalt_06's Avatar
tunes probly pig rich
Old Jun 22, 2010 | 08:29 PM
Redefined1's Avatar
sounds very rich to me. check your plugs. if they are covered in black on the tip then you are for sure running rich.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
grampss
Sep 27, 2015 08:51 PM
