Best cooling mods
Old Jun 20, 2008 | 08:09 AM
SS4speed's Avatar
Best cooling mods
hey guys, I was wronding what is the best cooling mods for my set up. mods are in the sig
Old Jun 20, 2008 | 08:10 AM
Altiery54's Avatar
h/e for now. any smaller pully and u want meth
Old Jun 20, 2008 | 08:13 AM
SS4speed's Avatar
what are the best brands
Old Jun 20, 2008 | 10:15 AM
Zach06CobaltSC's Avatar
cx racing heat exchanger setup, i forget who sells it, but it comes with brackets, hoses, clamps, everything you need to hookup. I personally have the AEM meth kit and see no issues with it, however I won't have it completely installed until Monday. Then obviously the dual pass end plate with option b.
Old Jun 20, 2008 | 10:41 AM
lsjwannabe's Avatar
ottperformance.com they also sell devils own meth kits
Old Jun 20, 2008 | 11:51 AM
LamboW9's Avatar
yea definitely get a meth kit...its cheaper than the h/e and you can see some power gains if you get tuned for it and it cools better than a h/e also...h/e's are only 60% efficient
Old Jun 20, 2008 | 11:52 AM
invisible's Avatar
Originally Posted by denny
I am going to say Meth/water injection.
Easy, no contest. I prefer Devils Own Progressive
LamboW9's Avatar
plus you get a higher octane and eliminate knock with the meth kit as well as stabilizing detonation so your gettin a long engine life as well as cooling with the meth
AIS water/meth kit FTW
Old Jun 20, 2008 | 11:54 AM
Kibosh3's Avatar
theyre both good to have...meth has more advantages tho...
QuikSilverSS's Avatar
I have the Cobalt Addiction Heat exchanger which i love, and the Devils Own meth kit which is awesome...meth is the best cooling mod but you need tuned otherwise you are going run stupid rich air fuel ratio!
Old Jul 14, 2008 | 10:10 PM
KevinDouse1's Avatar
i HAVE THE STAGE 2 TUNE IS THAT GOOD FOR THE METH...........OR I NEED AN AFTERMARKET TUNED......
Old Jul 14, 2008 | 10:25 PM
restonSS's Avatar
you need an aftermarket tune
Old Jul 14, 2008 | 10:49 PM
tlax23's Avatar
The CX Racing h/e and a dual pass endplate will suit your setup just fine. If you decide to do the h/e buy it off of ebay.... The brackets are practically made for the cobalt and all the other materials can easily be had at your closest autozone. All you need other than
the h/e itself is about 5 feet of 3/4 inch heater hose, four 3/4inch hose clamps, some self-tapping screws, extra coolant, some beer and a buddy. About 10$ total (not including the beer)
The cx h/e off of ebay is 150 bucks plus shipping. My iat2's went from around 150 to 115-120 with just the h/e. Im running a 2.9 with all the necessary supporting mods.
Meth is the best cooling mod however I just dont have an easy way to get tuned.
Old Jul 15, 2008 | 07:52 AM
-Jayson-'s Avatar
a cheap easy one is a coolant resevoir, i just did this last weekend. Works well top end seems to have picked up some ponies by the butt dyno and the engine doesnt feel heat soaked as quickly.
Old Jul 15, 2008 | 08:41 AM
You will see the benefits of the cooling and high octane properties of the meth will prevent knock and timing being pulled, however the hp gain will be offset by the fact that you will be in the 9's a/f wise on the stage 2 tune. I was off my widebands scale rich wise when I had the stage 2 and the meth hooked up.
I currently run a 11.4 a/f with my 5gph nozzle and a 75/25 meth/water mix. a 50/50 mix leans me out to a 11.8-11.9 a/f. I am HP tuned now
bigdeertz
Nov 17, 2016 09:41 AM
dennis69
Oct 20, 2015 04:49 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
