Best IAT2s?
Old Feb 10, 2009 | 11:13 AM
flash13brandon's Avatar
Best IAT2s?
I'm not sure if this has been talked about before, but I haven't seen it. What IAT2s give the best performance? I know the colder the better blah blah blah. But i'm looking for specific numbers that are possible to achieve in 80 degree+ weather. For example, is there a difference between xxx degrees and xxx degrees as far as performance?
Old Feb 10, 2009 | 11:18 AM
ShortStack's Avatar
Anything above 140-150 loses performance.
Also depends on the tune.. you can make the ecu pull spark later or sooner.
And even if you tuned it so it would pull spark at a higher temp, things would still go wrong with detonation.
Last edited by ShortStack; Feb 10, 2009 at 11:18 AM. Reason: Automerged Doublepost
Old Feb 10, 2009 | 11:19 AM
Johnboy12358's Avatar
I think that at around 122F the stock tunes and stage tunes from GM start to pull time...
Someone correct me if I am wrong.
Old Feb 10, 2009 | 11:20 AM
Shortstack, So you're saying that there is no difference between 130 and 100 performance wise?
Old Feb 10, 2009 | 11:24 AM
ShortStack's Avatar
No not so much...I mean... 130 could be considered a wee bit high.. but... Tune speaking, no.
You may lose some power due to air density (hot air is less dense).. but probly not till you go over 130 or so
Last edited by ShortStack; Feb 10, 2009 at 11:24 AM. Reason: Automerged Doublepost
Old Feb 10, 2009 | 12:27 PM
wtpcobaltss's Avatar
yea i have ott stage 1 with 2 h/e and wot ive hit 180 iats...thats way to much and i guess meth is def. but what is everyone else getting on this kit??? maybe my pumps weak.
1badBlueberrySC's Avatar
OOH OOH can I play!
110-113* IAT2s after a 3rd gear WOT pull!
Old Feb 10, 2009 | 12:29 PM
What all cooling mods do you have blueberry?
Old Feb 10, 2009 | 12:32 PM
Originally Posted by 1badBlueberrySC
OOH OOH can I play!
wow, thats nice... I only get that if its like 50 outside
Old Feb 10, 2009 | 12:33 PM
Cobra H/E and meth injection plus I use more distilled water with a splash of coolant in my H/E fluid!
ShortStack's Avatar
Dude you should be no where near that number...
whats your secondary h/e?
I dont have any cooling mods and im no where near that.
Old Feb 10, 2009 | 12:35 PM
invisible's Avatar
I bet his H/E pump is out.
Old Feb 10, 2009 | 12:37 PM
ShortStack's Avatar
Agreed.
invisible's Avatar
Originally Posted by ShortStack
Agreed.
Bout time. j/k
Old Feb 10, 2009 | 12:43 PM
iisbalt's Avatar
141 IAT2 after dead stop till top of 4th gear. So 130ish after 3rd gear pull.
All I have is CAI and 2nd heat exchanger.
Timing is pulled by two after 141 and then as temp rises it pulls more.
Difference between say 80 and 130 is gonna be roughly 10hp at best. Remeber the colder the better which is why nitrous (sprayed at -65 degrees ) provides a bigger help to S/C users than N/A.
As long as you keep the IAT2 below 120 (in Florida) your doing good and can bump the timing a few degrees as long as it will stay in that range.
hatrickstu's Avatar
OOH OOH can I play!
and the IAT1's were what?
Old Feb 10, 2009 | 12:47 PM
Zach06CobaltSC's Avatar
During the winter I don't think its possible for me to hit over 100 on my iat2's, during the summer though they hover right around 105 to 115 depending on how many back to back pulls I do. Gotta love meth.
Old Feb 10, 2009 | 01:11 PM
ShortStack's Avatar
Originally Posted by invisible
Bout time. j/k
lol.
Old Feb 10, 2009 | 01:13 PM
RedEcotecSS's Avatar
OOH OOH can I play!
i'm somewhere around there
Old Feb 10, 2009 | 01:16 PM
Not yet your not... Jason told me you were in the 140's! but you are in the "OK" range!
Looks like I'm gonna be getting Meth ...Its gonna start getting hot down here in the next month or so. How much help is dual pass?
High 80's
Old Feb 10, 2009 | 01:20 PM
Bika's Avatar
Fail Less.
my c/a heat exchanger didnt seem to help much if at all. i was running a 2.8" with 60s. on an 80+ degree day my iat2 would see 145 after a pass down the 1/4.
blah. i need mef but dont wanna spend the $
ShortStack's Avatar
Its not like 50 thousand degree difference.. it mostly helps with getting the coolant in and out of the intake manifold faster so it could be cooled by the heat exchanger.
Old Feb 10, 2009 | 01:23 PM
k. I'll prolly just grab meth instead
