best MAF sensor
Old Sep 29, 2008 | 04:48 PM
simmonsnick's Avatar
best MAF sensor
what is the best mass air flow sensor too use on our cars?? i think mine is bad!! and where do i get one??
thanks guys
Old Sep 29, 2008 | 04:50 PM
camarokiller's Avatar
Im pretty sure there are none other than stock available.
Old Sep 29, 2008 | 07:44 PM
HunterKiller89's Avatar
^^ i thinks too... Im pretty sure the cobalts all use the same MAF, and since its frequency based, and has been run to 400whp without being oegged, theres really no reason for anyone to upgrade.
Old Sep 29, 2008 | 11:23 PM
bolus's Avatar
I'm using an LS7 maf. much better
Old Sep 30, 2008 | 12:11 AM
Kennyspec's Avatar
also some guys perfer to convert to the Redline style MAF.
Old Sep 30, 2008 | 05:18 PM
i was going to say i know i have seen peps useing diff maf sensors i have hptuners and its telling me dtc maf high fre is on and dont know if it is bad or its a bad intake set up. i made some changes to the intake and cleared the codes i have not read the codes lately but if it is bad i want the best to go back in!!!! U KNOW
thanks again
Old Sep 30, 2008 | 10:11 PM
bolus's Avatar
I was actually joking since the LS7 maf is the same part number as the LSJ maf. If it is good enough for a corvette it is good enough for the cobalt.
Old Oct 1, 2008 | 05:27 AM
thanks again
im sure the ECU is seeing extra airflow that its not programmed to see. its not an issue with the MAF so much as it is an issue with the tune your running. readjust the tune you have so that it doesnt think the airflows its seeing are bad.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
