Best way to bleed.
Old Mar 9, 2010 | 10:11 AM
Unforgiv3n's Avatar
Best way to bleed.
I've had a new intercooler pump waiting for me to install, now that it is becoming much warmer out. I think its about time.
I known when installing this I will need to bleed my system. What is the best way to do this? I have ZZP stage 3 HE and stoch HE, and do NOT have dualpass/opt b.
So what is the best way to do this?
Thanks!
Old Mar 9, 2010 | 12:12 PM
Frew's Avatar
I thought this was some emo thread when I first saw the title lol
Old Mar 9, 2010 | 12:18 PM
jbenso4's Avatar
x2 lol im going to have the same question too when i bleed my H/e
Old Mar 9, 2010 | 12:30 PM
insylem's Avatar
Talking
I thought it was about brakes
Old Mar 9, 2010 | 12:54 PM
qwikredline's Avatar
get option B. cheap, ez.
Old Mar 9, 2010 | 02:48 PM
ziggity's Avatar
theres a bleeder on your stock heat exchanger .. take it out and fill up your system until you see coolant coming out then put it back in, keep filling till you see regular level in your filler neck. start car and leave the cap off ( your level is going to start dropping, add coolant as it does). When your level seems to be staying where it should be you should be good but keep an eye on it for the first little while and add coolant if needed.
Old Mar 9, 2010 | 07:24 PM
Unforgiv3n's Avatar
I do not have dual pass, how would I route the opt b?
Good info, thank you. Is this at the bottom of the HE?
Old Mar 9, 2010 | 09:22 PM
ziggity's Avatar
No its at the top of the stock heat exchanger on the passenger side .. its just a small plug into it.
blueLNFftw
Apr 3, 2015 03:50 PM
eatinJDM
Oct 25, 2014 09:15 AM
efrommel
Sep 25, 2013 05:28 PM
JoeBMX
How to Guide
24
Mar 26, 2013 03:10 PM
