Best Way to install Hub on supercharger?
Old May 20, 2008 | 03:05 PM
Saltbager's Avatar
I need to know wahts the best way to install the hub onto the snout of the supercharger without buying the tool from CA or someone ... i'm affraid that a pulley installer like a power steering type might break offin the threads .....
Old May 20, 2008 | 03:47 PM
nherbst454's Avatar
Here's the tool I make for pulley removal/hub installation...
http://www.smoothflowpulleys.com/Pulley_Puller.html
Old May 20, 2008 | 03:49 PM
Drakonen2000's Avatar
i really think the cost of getting a pully puller / installer from a vendor is nothing in comparison to ruining the snout of the charger when you are beating it with a hammer trying to change the hub...just get the puller
Old May 20, 2008 | 03:56 PM
ItalianJoe1's Avatar
Those powersteering pulley tools work great if you know how to use them, i've done probably 5 pulley installs using them, works every time, never had a problem.
Old May 20, 2008 | 04:07 PM
YELLERCOLT's Avatar
Take It To The Dealer.
Old May 20, 2008 | 08:58 PM
qwikredline's Avatar
i purchased Nates tool I am 100% satisfied. The Snap On power steering tool is absolutely awesome that ItalianJoe uses, but if you do use it , an electric impact helps ...its not an easy task, so in the end, I suggest you go to a qualified tech with the tools.
Old May 21, 2008 | 10:27 AM
Saltbager's Avatar
I was going to throw the charger in the freezer and the put the hub in the toaster oven at about 300 degrees and then press it on with a power stering installer. But i will have to get on from snap on today because the threads in the snout are m8x1.25.... so i willl have to see what he has for me.
Old May 21, 2008 | 10:40 AM
I don't think the heating/cooling will make that much of a difference, but it can't hurt.
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
Sep 30, 2015 07:22 AM
cw383
Sep 30, 2015 12:41 AM
Bohb
Sep 27, 2015 09:11 PM
