Best Wideband...
Old Oct 26, 2006 | 04:31 PM
NJHK's Avatar
I will always say the best wideband to use is a Zeitronix unit. It's not a pillar type gauge, it's very low prifle. You'll be able to read your: Boost, A/F Ratio, EGT & Lamda through this gauge. Slightly bigger than an Turbo Timer and you can put it anywhere.
This is the Unit:
This is the actual gauge:
To get the full setup, this is what you'll get:
I had it on my sunfire but never took any pictures of it installed, unfortunately. If you want more information on it, check out www.zeitronix.com
Slightly pricey but it's very very good to have.
Old Oct 26, 2006 | 04:34 PM
Mase's Avatar
I use the AEM and it's damn accurate, as soon as I go into WOT the AFR drops
Old Oct 26, 2006 | 04:35 PM
CTCOBALTSSS's Avatar
Originally Posted by leviticus88
So the wideband read out is through the interceptor so we don't have to put more gauges in.
OK, I get it. I don't know why people wouldn't just want to see the gauge but OK.
That wideband looks cool. ^^^^^
Old Oct 26, 2006 | 04:39 PM
NJHK's Avatar
The zeitronix one? Yeah it is.
This is what it looks like lit up:
Old Oct 26, 2006 | 04:41 PM
How much is that biotch? It doesn't say on the website.
Old Oct 26, 2006 | 04:49 PM
leviticus88's Avatar
I don't have a place to mount it and I'm broke.
Old Oct 26, 2006 | 04:58 PM
NJHK's Avatar
http://www.zeitronix.com/order/order.htm
Price went down for the full set...when I bought it was about $500. It's down to $399.
Old Oct 26, 2006 | 04:59 PM
NJHK's Avatar
Also, you can data-log via laptop & software.
Old Oct 26, 2006 | 05:14 PM
HViper's Avatar
Thats the wideband I am going with, was going with AEM, but that will work way better. Thanks NJHK
Old Oct 26, 2006 | 05:17 PM
NJHK's Avatar
No problem. Glad I can help.
Old Oct 26, 2006 | 05:44 PM
  #36
cashstacker's Avatar
Originally Posted by NJHK
Yes. The closer to the motor, the more accurate.
THe manual says not to put it within a foot of the motor I believe. I knw my friend had is in the o2 housing on his srts and I believe it wasn't very accurate.
Old Oct 26, 2006 | 05:56 PM
  #37
NJHK's Avatar
Now that I'm thinking about it...I'm thinking in reference of my turbochargered system. It was close to the turbocharger, about the top of the downpipe. It seemed pretty accurate.
I don't know about the "average" distance that people should have it though from the wideband sensor and the motor itself.
Old Oct 26, 2006 | 05:58 PM
  #38
CobaltPerformanceParts's Avatar
1 -2 feet from that engine is the general rule. Turbocharged applications you ussually want to be a lil further then none turbos. Too much heat can kill them. Make sure you calibrate them in the open air also and not inside your exhaust. The lc-1 has digital input, output, and 2 programmable analog outputs.
Old Oct 26, 2006 | 06:01 PM
  #39
NJHK's Avatar
Thanks for the tip.
Old Oct 26, 2006 | 06:21 PM
  #40
joeworkstoohard's Avatar
i'm impressed that anyone still knew the term "lamda"
Old Oct 26, 2006 | 06:35 PM
  #41
Can someone explain how to calibrate and what it actaully means/does? Thanx
Old Oct 26, 2006 | 06:41 PM
  #42
NJHK's Avatar
lol yeah
Old Oct 26, 2006 | 06:57 PM
  #43
basically, you're setting a baseline for the sensor. back in the day, and on really old cars that meant sitting with a heat gun till it got warm and then setting it up, now i think you just push a button with the o2 sensor dangleing, and then bolt it in.
Old Oct 26, 2006 | 07:12 PM
  #44
NJHK's Avatar
I think the zeitronix sensor that they send you is already calibrated...I'm mainly going off of memory though.
Old Oct 27, 2006 | 12:44 PM
  #45
So what is the cheapest wideband that is at least decent?
Old Oct 30, 2006 | 10:10 AM
  #46
R33P3R007's Avatar
360 L337 User
not sure ^^ but AEM seems good.
Can the Balt use that zeitronix one
Old Oct 30, 2006 | 10:15 AM
  #47
patathSS's Avatar
Prolly the LC-1 is the cheapest. It was a pain in the ass to wire but I think it was cause I wasn't sure what I was doing. I would have bought an AEM or LM-1 if I had to do it again.
Old Oct 30, 2006 | 10:18 AM
  #48
djt81185's Avatar
Plx devices m-300 FTMFW!
Dan
  #49
Cool sounds like aem is the way to go.
elecblue06
Nov 22, 2011 06:55 PM
volsfan92
Sep 27, 2011 02:41 PM
volsfan92
Sep 26, 2011 08:56 PM
cardelino18
Nov 24, 2010 01:04 PM
r0k0
Dec 2, 2007 06:45 PM
