Black smoke?
Old Jan 22, 2010 | 02:50 AM
Caligula's Avatar
Black smoke?
My friends keep telling me that whenever I speed up really fast, it blows out alot of black smoke? Is this normal?
I've had enough issues with this car lately.
Old Jan 22, 2010 | 02:58 AM
asherby85's Avatar
running really rich?
Old Jan 22, 2010 | 02:59 AM
ChriSS/SC's Avatar
^ x2..
check!
Old Jan 22, 2010 | 03:00 AM
Caligula's Avatar
Had alot of problems with it recently, but since i've got all the problems fixed, it is running better then ever.
Untill my friend brought this up to me yesterday.
I smelled a burning smell for about a week, smelled like the clutch, but thats gone away now.
Old Jan 22, 2010 | 03:02 AM
ChriSS/SC's Avatar
running rich isn't exactly a BAD thing.. and you wont feel it "running bad" depending on how rich it is.. make sure to check next time.. that's probably what it is.
Old Jan 22, 2010 | 03:04 AM
Caligula's Avatar
It has been useing more gas, but how does 'running rich' even happen?
I havent done any mods to the engine in forever.
Old Jan 22, 2010 | 03:06 AM
ChriSS/SC's Avatar
Maybe it's BEEN running rich for a while and now is the first time someone said anything about it? Haha if you're running really rich you could lean it out and the car will actually run better too.
Old Jan 22, 2010 | 03:08 AM
Caligula's Avatar
Maybe it has been doing it for awhile.
I really dont know.
Would it make a burning smell similar to a clutch though?
Old Jan 22, 2010 | 03:30 AM
ChriSS/SC's Avatar
Burning smell yeah.. but not clutch smell..
Old Jan 22, 2010 | 03:37 AM
Caligula's Avatar
Weird, others said whatever it was smelled like a clutch, hopefully the smell doesnt come back.
Old Jan 22, 2010 | 03:44 AM
ChriSS/SC's Avatar
lol.. the smell will be there..
And some people will just say it smells like clutch.. even though they don't even know what clutch smells like..
Check it out for yourself..
Old Jan 22, 2010 | 09:17 AM
Greg Ventrone's Avatar
mine sometimes smellss i cant say like clutch cuz idk what that smells like but its weird but i dont have a black smoke problem. the smell might be from the sc?
Old Jan 22, 2010 | 09:28 AM
DarkCobalt13's Avatar
check your coolant temps next time the car is warmed up. Could be she isnt getting up to full temp, or it could be the bank 1 O2 sensor not quite reading properly
Old Jan 22, 2010 | 09:31 AM
jlong3382's Avatar
Did you get the diesel performance option?
If your running rich all of a sudden huh? Pull your spark plugs and see what they look like. A spark plug can tell you alot about how your engine runs.
Old Jan 22, 2010 | 09:33 AM
yeah, just turn up the injector pump and start coughing..... That **** is annoying, but funny when they go too high and have to crimp the fuel lines to get the motor to shut down
Old Jan 22, 2010 | 09:37 AM
PSHHH's Avatar
https://www.cobaltss.net/forums/show...k+smoke&page=2
there is like 5 diff post on this -_-...but yea fuel.
Old Jan 22, 2010 | 09:43 AM
fuel
Old Jan 22, 2010 | 09:46 AM
Yes its over fueling, this is obvious, but thats not the answer
Old Jan 22, 2010 | 09:49 AM
well i wouldnt exactly say that its normal would you?
Old Jan 22, 2010 | 10:02 AM
Nope, not normal. There are several things that can cause it. The Stage 2 mod could be the cause. Could be an O2 sensor, could be the coolant temp sensor, could be the MAF sensor, could be several others. Best thing to do is take it to a shop especially if its still under warranty, unless the OP knows someone with an advanced obdII scan tool like a Snap-On Solus
Old Jan 22, 2010 | 11:17 AM
Illini_06SS's Avatar
Does it have GM Stage 2 tune? Cause that's supposed to be a fuel hog. Looks like it may be time to invest in a wideband to keep an eye on AFR's. If you go WOT, you should expect to get some black smoke out the tailpipe for a split second until the system can level itself out, but over-riching is better than going too lean...
Old Jan 22, 2010 | 12:55 PM
Lean=Mean, just as long as its not overboard
Old Jan 25, 2010 | 08:29 AM
my car is gmstg2 and tuned and i dont have a black smoke problem so that may be it.
Old Jan 25, 2010 | 10:01 AM
Yes, but too lean = BOOM!
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
717ssbalt
Oct 2, 2015 04:01 PM
