Belt tensioner change
My belt tensioner has some slop from side to side. I want to change it, but it looks like I have to remove the super charger pulley to do so. Does that pully come off easy? Or do I have to remove the whole sc? Any info that you have would be greatly appreciated.
You compress the belt tensioner by pressing down on the little notch by the tensioner pulley with a 15mm wrench (this can sometimes be a real pain. help from a buddy is recommended). That will give it the slack it needs to take the belt off. At that point the supercharger pulley shouldnt matter.
If you do find that you need to take the s/c pulley off for whatever reason though, you'll need to unbolt the supercharger and take it to get the pulley pressed off.
use this as reference:
https://www.cobaltss.net/forums/how-guide-43/how-install-zzp-modular-pulley-your-cobalt-ss-sc-25841/
i recommend a crow bar with a towel, lots easier to get belt off, just remove bolt thats holding the tentioner on and replace.
I'll give it a shot, but it just looks like the bolt that holds the tensioner on, is right behind the SC Pulley.
