BlazinbaltSS Rebuild Thread
Old Dec 28, 2008 | 09:48 AM
blazinbaltss's Avatar
Update new pictures on page 6 The date is March 8th 2009
Well Guys As Most Of You Know I Blew Up My Engine The Other Day So Now Im Rebuilding!!!! We started on Dec 27,2008
So here is what i am doing to the motor
boreing to .15 over
Diamond forged .15 over pistons
did a head job on it new seals and valves
Exedy Clutch Kit
Arp Head Studs
Cometic Head Gasket
Painting Supercharger and Valve cover
Also BC2 Body Kit will be put on during process
Here is a picture of the engine when it blew.
here is some taking apart pictures before i have to pull the motor
Fuel rail off
Fuel rail
Supercharger off (2 pics)
Supercharger (2pics)
Intense 2.70 pulley
2 pictures of the intake mani off car
Picture of engine intake mani off car
Where the AC Was
Some parts that we took off in the trunk
Valve cover off
haaha looks like someone changes his oil not bad for 48000 miles on it!!!
Cams
Last 2 pics of day not to bad for first days work
Next Day we are working on it is December 29,2008 Pics up soon
By the way when i say we are building it i am reffering to me(Brian) and my friend eric!Ha were both 18!!!
Old Dec 28, 2008 | 09:52 AM
originaladrian's Avatar
unsubd last thread, Subd this thread lol.
good stuff. GL
Old Dec 28, 2008 | 10:32 AM
good stuff. GL
thanks man me and him are going to due are bests in the gm book were going bye thee rebuild and it says the stock cams and valves can hold over 300 and so can the connecting rods. So as far as stuff goes now Im getting the Cometic Head Gasket and Diamond Racing forged Pistons and rings. Might put new clutch in and might due cams but not to sure yet still plenty of time to decide
bump any comments
Last edited by blazinbaltss; Dec 28, 2008 at 10:32 AM. Reason: Automerged Doublepost
Old Dec 28, 2008 | 10:33 AM
kburgess04's Avatar
good luck!!
so glad im not voiding my 5 year 100k on my car
Old Dec 28, 2008 | 10:49 AM
yea i didnt have that warrenty
Old Dec 28, 2008 | 10:51 AM
Zach06CobaltSC's Avatar
Looks good bro. I am assuming you are staying with stock compression pistons?
Old Dec 28, 2008 | 04:38 PM
WSFrazier's Avatar
Good luck, like I said in the other thread. Cracking open the A/C line just gave you more work than was needed. Also, if you are just doing pistons on the bottom end, don't even bother dropping the motor. You are just wasting valuable time. This all can be done in 8-10 hours start to finish.
Old Dec 28, 2008 | 04:45 PM
-Jayson-'s Avatar
I did this last summer with my friend, trust me, store and label every bolt into bags, you will be much happier and get done alot sooner.
Old Dec 28, 2008 | 08:09 PM
stonny9's Avatar
U better do at least a little porting to the IM and supercharger while u have it off.
Old Dec 28, 2008 | 08:25 PM
07YellowSS's Avatar
Your trunk carpet isnt gunna look to great I never realized how close of a fit the 2.7 is. Good luck with the build
Old Dec 28, 2008 | 10:03 PM
thanks everyone were trying are best and where puttind diamond pistons in so whetever compression they are not going to worry about porting the im and supercharger to much money for like little horsepower gain
Old Dec 28, 2008 | 10:25 PM
coopn8r's Avatar
You'd be suprised on the hp gains and cooling of the iat's with the manifold and the blower being ported. Just saying . Good luck. Subscribed
Old Dec 29, 2008 | 10:10 AM
thanks man
Timing Chain Off
Head off
Number 4 Valves All Oilly HA
What done up to this point time for motor to be pulled
new pictures guys
Last edited by blazinbaltss; Dec 29, 2008 at 10:10 AM. Reason: Automerged Doublepost
Old Dec 29, 2008 | 10:16 AM
Darkmanx's Avatar
Why are you pulling the motor to change pistons?
Old Dec 29, 2008 | 10:35 AM
because i want to my gosh does anybody read these threads im cleaning all the parts and outting new stuff in so that my 48000 mile car has basically zero miles on the new engine
Old Dec 29, 2008 | 11:14 AM
rallycobalt06's Avatar
i wish you luck man.......
Old Dec 29, 2008 | 11:18 AM
Darkmanx's Avatar
so why are you dropping the engine if your just changing pistons.
Old Dec 29, 2008 | 11:28 AM
glen229's Avatar
did it rain when you took the head off?
Old Dec 29, 2008 | 11:42 AM
victory_red_SS's Avatar
LSX RWD S/C conversion
I get the removing the engine to clean everything up but I don't understand why you removed the head first.
Also, just a heads up for the next time, the A/C line doesn't need to be removed to pull off the I/M. I have pulled 3 LSJ's out of my car and not once did I need to drain the A/C or disconnect a line.
Old Dec 29, 2008 | 11:45 AM
07LaserBlueSS's Avatar
Looks like coolant in the cylinders
Old Dec 29, 2008 | 11:52 AM
yes i left the hood open lol haha anyway thanks matt ill keep u updated and everyone else i just wanted to take the head off in the car ok im sorry its my first time and im not the best at it but thanks for everyone explaining
Old Dec 31, 2008 | 09:18 AM
took the head to a machine shop last night to get checked pulling motor tonight and i painted supercharger and valve cover
Old Jan 17, 2009 | 08:13 PM
getting th head from the machine shop back monday it was 373 dollars and taking the block down to get checked
Old Jan 18, 2009 | 12:34 AM
Jrcz24's Avatar
The progress looks really good. Keep it up!
Old Jan 18, 2009 | 01:06 AM
WSFrazier's Avatar
373 dollars to do what to the head?
