Blow-off valves?
Old Mar 6, 2006 | 10:52 AM
jmfss2nr's Avatar
Blow-off valves?
Hey everyone, I wuz reading in modified mag that this kid put a bov on his supercharged acura. I never heard of a bov on a supercharger. Is it possible? If so, what r sum positives and negatives bout it. Thanx
Old Mar 6, 2006 | 10:54 AM
c7015's Avatar
Pro ...........mindless retards think your car sounds cool
Negative ...you're a ricer
SEARCH !!!
Old Mar 6, 2006 | 11:47 AM
Pully Police's Avatar
SEARCH !!!
If the SC was a centrifugal unit, you could put a BOV or diverter valve (back to the airbox) on it as the throttle plate would be located AFTER the SC and there would need to be a way for built up pressure to vent if the throttle is snapped shut.
-P
Old Mar 6, 2006 | 11:54 AM
BullDog71ss's Avatar
Usually the centrifugal kits have a recirc instead of a blow-off.
Old Mar 6, 2006 | 01:22 PM
c7015's Avatar
-P
its not nessasary on SC cars is the point ...no matter how many IF's you throw at it
IF the car was Turbo we would need one
Old Mar 6, 2006 | 01:38 PM
Chris_20133's Avatar
this all good info but does it hurt it 2 put 1 on or wat thanks
Old Mar 6, 2006 | 01:58 PM
You cannot get a blow-off to work on our cars.
Old Mar 6, 2006 | 03:04 PM
bmoreyellowss's Avatar
Hahahaha no we have no need for a bov and plus it sounds cool for about 10mins than it becomes very anoying
Old Mar 6, 2006 | 03:24 PM
TXRLU's Avatar
Hmmm, I think this is what you are looking for...........Just make sure if you install it in your car, not to post it anywhere on the forums.
http://www.sunamiturbo.com/
Old Mar 6, 2006 | 04:59 PM
Worst things ever made for any vehicle. I want 3.
zinner's Avatar
Moderator Alumni
You could definetly use one on a centrifugal supercharger. I thought the big advantage of a blow off valve was to maintain impeller speed on a turbocharger which really isn't a problem on centrifugal since it's powered by the drive belt.
Old Mar 6, 2006 | 07:21 PM
That is more along the lines of a recirc/diverter valve. It dumps the charge back to the intake pre-SC and post-MAF so that the car does not re-meter the air. A BOV will allow the turbo to keep speed, however it dumps the charge to atmosphere which can cause some ECUs to freak out as the metered air cannot be accounted for. For an SC, a diverter will help equalize the pressure differential betwen the inlet and intake manifold once you are off throttle which will smooth out the way the engine reacts during a gearshift.
-P
Old Mar 8, 2006 | 01:20 PM
oooooo i got it now 4get the blow off valve and work on getin the intenes stage 3 kit thanks
Old Mar 8, 2006 | 05:04 PM
Basically...yes. Our SC's have an integrated diverter/recirc valve....so mod away and dont worry bout it
-P
Old Dec 12, 2007 | 03:21 PM
blkssbolt's Avatar
Did you have any luck?
Old Dec 12, 2007 | 03:32 PM
PuSha050's Avatar
completely not true.. IF it was centrifugal supercharged then a blow off valve is needed
roots type and twin screws dont use blow off valves
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
yellow dragon
Sep 28, 2015 09:49 PM
Trav3480
Sep 28, 2015 02:46 PM
dennis69
Sep 28, 2015 02:16 PM
