blue bolt replacements
Old Jul 4, 2007 | 03:05 PM
RedEcotecSS's Avatar
I'm changing out my pulley today (hopefully). I want to replace those GMS2 blue bolts with some allen head bolts. I believe the size is metric 8x16 but just wanna double check. Can anyone confirm this? Thanks!
Old Jul 4, 2007 | 03:06 PM
syP's Avatar
syP
talk to Nate.
that is if you can get the blue bolts out.. hah
better have a bolt extractor at your side.
Old Jul 4, 2007 | 03:08 PM
yeah, they're going to be a bitch but ima try my best. if i can't then oh well.. haha.
Old Jul 4, 2007 | 03:30 PM
syP's Avatar
syP
the bolt extractor sockets WILL get them off... SEARS has them.
Old Jul 4, 2007 | 03:32 PM
bolt extractor sockets, huh? would that be an easier route to go? how much are they? andddd will i need new replacement bolts after i get them off or would i be able to put them back on?
Old Jul 4, 2007 | 03:34 PM
an0malous's Avatar
when i went to play with mine, it was with large trepedation.
i had heard all the storys.....
I just about broke my knuckle when it let loose because i was pushing expecting major resistance lol.
Guess my dealership gave it the proper torque rating, instead of the stupid amounts other people have had to deal with.
PHEW.
Old Jul 4, 2007 | 03:36 PM
syP's Avatar
syP
Yea, mine was probably over 75ft/lbs.... no way it was under that.
it would be easier... but try the GM stage 2 socket, until you strip them
buy the hex-key bolts from nate
Old Jul 4, 2007 | 03:37 PM
wallas06SS's Avatar
Maybe the dealership didn't put that damn lock tite on there. Mine came off easily.
Old Jul 4, 2007 | 03:46 PM
an0malous's Avatar
the torque needed for mine consisted of my left hand on my normal socket wrench, and my right hand holding the pully still and a little jerk.
very very easy. ive got it down to a 10 minute job now to pullyswap.
Old Jul 9, 2007 | 06:40 PM
sscobaltscZ06's Avatar
Man, I have a 18" breaker bar on my ratchet and I cannot break the stage 2 blue bolts loose. Im afraid if I keep trying its gonna strip or bust the socket.
I was thinking maybe these suckers are reverse threads! LOL
Obviously my dealer used damn loctite (probably red stuff) and torqued the hell out of them instead of instructions 15 ft/lbs
Old Jul 9, 2007 | 06:47 PM
they're made to be tightened and not loosened. look closely at the bits...
Old Jul 9, 2007 | 06:55 PM
Yea definatly, but I can break a 100 ft/lbs bolt loose with a 18" breaker bar, but these wont break loose. I suspect red loctite was used that needs to be heated up and impact used to loosen. If I knew then what I know now I would have told the tech not to use loctite since it aint in the directions to do so.
Note: I just torched each bolt and tried to break each one free after heating the hell out of it with my torque wrench set at 125 ft/lbs and it didnt click at that, still no breaky loose.
Ok...update...
I got a impact gun in there and got a good shot on one of the bolts and it DID NOT break it loose. Im really surprised the bit hasnt broken or stripped a head with all this. The problem is the pulley cannot stay locked down without moving even with the impact on it.
My buddy who is the parts manager at the dealer where it was bought said any tampering with those blue bolts will void any engine warrranty claims. He said they look at the heads and can tell if someone has removed and put back on the bolts to change pullies.
So...I will give it one more shot tomorrow taking off the belt and applying torch till the bolt heads glow and if that doesnt work I have a 2.85 pulley for sale!
Old Jul 9, 2007 | 11:02 PM
ReMz's Avatar
Ok...update...
good god. and i thought i had a horror story about removing those bolts....
i dont know what to tell you other than i just kept trying and trying and trying. probably about 3-4 hours combined.
Old Jul 10, 2007 | 12:10 AM
I had forgotten what red/green loctite removal torque was and its ALOT. Even though I heated the bolts I didnt get it hot enough because the belt was still on, so ill remove it next and nuke the bolts and that should do it.
268 High Strength Threadlocker Red or green removal is 360 ft/lbs torque! If its heated up to 450 degrees it should break free easily while hot with very little torque required.
There aint no way the bolts are coming loose even with an impact gun unless they are heated to 450 degrees and removed hot when loctite red/green is used.
Old Jul 13, 2007 | 01:54 PM
UPDATE:
Well I have given up on breaking them loose!
Apparantly the tech used red or green loctite on them and even after heating them up with a 1700 degree torch for 30 seconds we still cannot break them free using a 18" breaker bar. You have to heat them up to melt the red/green loctite as with it dry they have a breakway torque of 400+ ft/lbs. I now suspect the tech using jb weld on the threads.
I am not pulling the S/C off to cut them off.
Anyone need a Nates 2.85 pulley local in San Francisco east bay as I have one that just went up for sale...
Old Jul 13, 2007 | 01:56 PM
M-Dub's Avatar
I didn't have any problems with mine, I have had it on and off several times! No problems! But PM Nate he has replacement hex key bolts!
Old Jul 13, 2007 | 01:58 PM
I have Nates bolts, the problem is we cant get the gm bolts off!
Old Jul 13, 2007 | 06:38 PM
invisible's Avatar
just drill them out and go get new ones
Old Jul 13, 2007 | 07:34 PM
tkaugh29's Avatar
dude, werid, i got my 2.9 today from nate, and i went out to check how tight my bluebotls were, and acutally with a normal sized ratchet i got them off no sweat. i jusst popped the proper extesnion onto the ratchet and they came off easy,!! its prolly just cause im unusually strong, all 160lbs of me! hah
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
