boost bypass mod
Old May 21, 2008 | 07:32 PM
thatotherguy's Avatar
boost bypass mod
how is that done???
Old May 21, 2008 | 07:33 PM
Scoot05RedSS's Avatar
There's a how to, hit up the search!
https://www.cobaltss.net/forums/show...t=boost+bypass I did it for you!
Old May 21, 2008 | 07:39 PM
InfinityzeN's Avatar
Just don't do it.
Old May 21, 2008 | 07:40 PM
blackngold20's Avatar
why would you want to do that?
Old May 21, 2008 | 07:46 PM
Psykostevo's Avatar
I recommend against bypassing that sensor, because it is used to reference tables within your tune. It is a ghetto mod, and not worth any performance. These superchargers are not set up to resrtict boost unless the temps get too hot, or the CAT overheats etc. Otherwise it will let you boost it all the way to begin with.
Old May 21, 2008 | 08:19 PM
Maxim_X's Avatar
There are 2. To get the most boost available from your sc. Put the actuator down as much as possible. 2 bolts allow you to adjust this.
Old May 21, 2008 | 08:24 PM
ok guys well I have a question. I run the boost bypass mod ALL THE TIME!! Because if I don't I will only build about 16lbs then by 7K be at about 13lbs. With the mod I see 17+ all through the rpms at WOT. Why? If someone can tell me why I lose boost and how to fix it, I will stop running the mod. Thanks guys
Old May 21, 2008 | 08:26 PM
Might have broken part of the bypass control.
Old May 21, 2008 | 08:28 PM
It's brand new, I have a new motor in and they had to special order the valve. Took forever to come in. Unless GM broke it!
Old May 22, 2008 | 02:45 PM
Psykostevo's Avatar
your tune may still have IAT boost limits built into it. in which case your car is pulling boost because the air is getting too hot. that can be disabled.
Old Jan 13, 2009 | 10:21 PM
r0k0's Avatar
i've got a question.. after 5500 im running 0 boost.. but from 0 to 5500 i have 17psi and then after 5500 0 psi
i've gotten this since i put my ZZP 3" header and DP and its been doing it since then
and when i get into boost since i got all my mods the supercharger kinda jumps on and off very quickly after 5500rpm
Denny told me to try this mod to see if its not the internal wastegate in the SC to be sure that might just be the problem or it might be something in the tune turned on and my tuner cant see it..
Thanks
PS Mods are listed in my Car Domain under r0k0tr
Thanks Again
r0k0
Old Jan 14, 2009 | 12:32 AM
coopn8r's Avatar
thatotherguy.. Is that Time in your sig spraying the n20.. If so.. Why is your trap so damned low? Sorry to thread jack.. Its bugging the **** out of me..
Old Jan 14, 2009 | 12:34 AM
Mnatvyc1223's Avatar
i never had to use the boost bypass mod and my car held 18psi all the way to redline, **** no one i know has used the boost bypass. me thinks it's a bad idea.
Old Jan 14, 2009 | 12:44 AM
coopn8r's Avatar
Just realized how far back this thread goes.. Lmao. Nice Revive Roko :P
Old Jan 14, 2009 | 12:46 AM
oh damn it is a revival, back from the dead.
Old Jan 14, 2009 | 12:54 AM
NexTnmE's Avatar
^Right. If your car is not holding boost until redline...then something is wrong. Boost should still, even slowly, climb until you shift...its just the nature of the supercharger...I don't really see the need for this mod...
With my 2.9" it jumps to 13psi under full throttle, around 3,00o rpms, then tops off around 16+ near redline...
turbochargedss2012
Sep 20, 2023 12:17 PM
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
