Boost Gauge
Old May 3, 2006 | 09:15 PM
Zoomyjs's Avatar
Boost Gauge
In the manual it says when the car is set to RUN(i assume that means engine on) the boost gauge should be at 0. mine has never been at 0. always idles at around -60KPA/-8.7PSI on the boost gauge... and maximum i've ever seen it boost to with RPM's at redline is like 70KPA=10PSI. Thought we were supposed to be like 12 stock. maybe its because my citys so high above sea level, dunno. anyone else notice this?
Old May 3, 2006 | 09:16 PM
l Sh1ft l's Avatar
mine barely goes above 10.
Old May 3, 2006 | 09:19 PM
d_backer1's Avatar
Do a search It takes time to break in the motor and then your boost will increase, as for the gauge reading 0 you need to shut the car off then turn the key to run position without starting it and your gauge will return to 0
Old May 3, 2006 | 09:28 PM
M88ArRamadi's Avatar
Mine has never gone past 10 PSI. I've had it for over 1000 mi.
Old May 3, 2006 | 09:30 PM
d_backer1's Avatar
Mine didn't reach 12.5 psi until I had about 3k on it
Old May 3, 2006 | 09:38 PM
l Sh1ft l's Avatar
I only have 250 Mi. That might be why.
Old May 3, 2006 | 09:42 PM
srt-killer's Avatar
ya probly cause mine took about 2500-300k till i could get 12psi.
Old May 3, 2006 | 09:54 PM
Jmc007's Avatar
Simply do the by-pass mod and you will get full boost.
Old May 3, 2006 | 10:00 PM
Zoomyjs's Avatar
ah nice, with the boost bypass how much PSI can you go up to with everything else stock?
Old May 3, 2006 | 10:05 PM
NJBLUESS's Avatar
No, putting the key in the "RUN" position, means" To place the ignition switch to the position before CRANK". Do not start the engine, just turn to the position before crank. You are checking to besure the gauge is calibrated.
Old May 3, 2006 | 10:09 PM
1stbluSS's Avatar
no ones guage reads 0 during idle it is in vaccum at that point...... also you will not see full boost until around 2k - 3k ... boost levels also depend on atmospheric pressure.
Also the boost bypass mod does not help you gain more boost with a stock set up it allows you to get all the boost you should from a pulley that puts out more than 12.5
Old May 3, 2006 | 10:35 PM
Zoomyjs's Avatar
k it all makes sense. yeah when just the key is inserted its at 0, then when the engine starts it drops. seems like everyone else has the same stock numbers. when i was around 1000km it was usually around 60KPA now that i just hit 2000km thats when i noticed sometimes going up to 70KPA.
Old Aug 6, 2006 | 05:21 PM
TCarter's Avatar
if your engine is on. your always gonna have a "negative" boost. until you give it some gas.
Old Aug 6, 2006 | 05:27 PM
cobss187's Avatar
you guys shouldnt be running it to 12-12.5 psi under 3000-3500 miles anyway! ouch BREAK IN PERIOD!
Old Aug 6, 2006 | 09:26 PM
cds00bsmg's Avatar
Im at 4200 miles, and have yet to see 12psi, at least not that Im aware of. I keep my eyes more on the tach than the boost gauge when Im getting into it. Isn't is not supposed to get to 12 or 12.5 until around 6-6500k?
Old Aug 14, 2006 | 11:39 PM
sealy's Avatar
i'm at about 1300 miles and the very few times i give it ****, it barely breaks 10 psi...i'm hoping that it still moves up eventually.
Old Aug 15, 2006 | 02:03 AM
SUKXOST's Avatar
im at 20K miles and I have the Stage 2 with about 200 miles on it......I'm getting 16 or 16.5lbs of boost! no ****....thought it would max at 15 I keep reading but I won't complain!!!! Stock it was a good 3K before I saw 12 PSI
Old Aug 15, 2006 | 02:18 AM
sealy's Avatar
^ thanks for the reassurance!
Old Aug 15, 2006 | 02:27 AM
cobss187's Avatar
its most likely cause of ur elevation too, i know guys with 15k on their car hitting 10lbs of boost, not near me tho. I didnt even hit 1000 miles and stupidly (once or twice) i went WOT and hit 12.5lbs. Its because of my location, im directly at sea level give or take 100 ft. Just look up some kind of elevation to boost ratio and see if your maxing out your boost according to elevation. Cant beat long island NY tho, SEA LEVEL!! FULL BOOST
Old Aug 16, 2006 | 03:33 PM
BradyB's Avatar
I'm at 1,100 miles and 4,000' ASL. I'm only seeing 10PSI, is there anybody else with my elevation that is seeing 12 PSI stock after a couple thousand miles? Anybody in CO or NM, I know albuquerque is at 5,000' ASL.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
