which boost gauge?
Old May 30, 2011 | 03:23 PM
G11's Avatar
G11
which boost gauge?
so now that i have my tvs i surpass the 20 psi and seein which boost gauge i should get and how to install...lol don't know if it i just a plug n play or if i have to do something else to get it too work
thanks
Old May 30, 2011 | 04:33 PM
insylem's Avatar
thanks
I use the 3.5 bar map sensor from Aeroforce and have it hooked to my Analogic. It will hoook to the interceptor too.
That is probably the best way to go. If you dont have an interceptor already, Id reccomend an interceptor. Reads all kindsof stuff from your OBDII port as wel as 2 analog inputs, one of wich you can use for a wideband, the other for a 3.5bar map sensor. Keep in mind that the Interceptor can/does read boost data from the OBDII port, and being digital, it might be able to go past 20 psi (If the PCM can see it past 20)
Old May 30, 2011 | 04:51 PM
G11's Avatar
G11
i do have a interceptor but i watch other things since i have a boost guage...i just think it is stupid that i can't get a accurate readin anymore lol!
Old May 30, 2011 | 06:11 PM
insylem's Avatar
You can go dual interceptor then. Bring up the Map and watch that. Its from the PCM so I dont know how accurate it is, but if that doesn't work for you, get the 3.5 bar map sensor from Aeroforce, and if you want, get an analogic gauge instead of a second interceptor.
Old May 31, 2011 | 12:21 AM
87gn06gto07irl's Avatar
T/c boost gauge and map sensor.
Old Jun 1, 2011 | 01:26 PM
G11's Avatar
G11
^^^i didn't know that would work...
Old Aug 31, 2011 | 05:35 PM
thebucky84's Avatar
does this actually work? Not sure on that one. I'm also in the hunt for a new Boost gauge. I don't want/need an interceptor, so what are some other suggestions? Anything out there that can be a plug and play with the existing wires from the stock gauge?
Old Aug 31, 2011 | 05:36 PM
paintballerr78's Avatar
i have the aem e series boost gauge and it reads up to 30 and lights up red
Old Aug 31, 2011 | 05:37 PM
TommyP's Avatar
AWD > FWD
Im 99 % sure a tc gauge won't work, they read differently. Same reason there are 2 different versions of the interceptor for the sc and tc balts.
Old Aug 31, 2011 | 05:38 PM
Projekt's Avatar
Autometer Cobalt 30 PSI gauge. I have it in my car and its great.
Old Aug 31, 2011 | 10:15 PM
thebucky84's Avatar
is it electrical or mechanical?
Old Aug 31, 2011 | 10:17 PM
rekameohs_nire's Avatar
i have the cobalt mechainal boost gauge and it works great and was easy to install. i only have the 20psi one but they have a 30psi as well
Old Aug 31, 2011 | 11:58 PM
Boosted05's Avatar
Or get a prosport boost gauge, they go to 25 psi. They are relatively inexpensive and the DSM/supra crowd loves em.
Old Sep 1, 2011 | 12:01 AM
Leafydialupking's Avatar
Yeah, love my pro sport electronic boost gauge. Not the fastest responding gauge but it should keep up with your boost in 2nd gear.
Old Sep 1, 2011 | 01:17 AM
thebucky84's Avatar
anybody using the RaceTech Red Angel Ring Boost gauge?
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
