I iz newbee
Old Aug 29, 2011 | 06:51 PM
Elusive's Avatar
I iz newbee
Yesterday I changed the plugs in my car and replaced the vacuum hoses!! Today met up with my friend to ride around and lost all power like the supercharger was blown or worse!! Had some white smoke coming from the exhaust. When I got home I puller her in the garage and low and behold I put the vacuum hoses in the wrong spot to the actuator. I had the bottom on the top and vise vs. It ran like crap!!
My question to the experienced did I do any damage to anything? I have been having a miss and thats why I did the plug change. Miss is still there somewhat and it seems like the car is being held back somewhat. Maybe cat is clogged? Thanks
Old Aug 29, 2011 | 06:54 PM
BPacak's Avatar
Vtec Rep
Your title is misleading and makes no sense for this thread lol.
so i change now.
Old Aug 29, 2011 | 06:59 PM
Silv3r's Avatar
You're not gonna know until you take it apart. White smoke isn't a good sign though.
Old Aug 29, 2011 | 07:05 PM
Elusive's Avatar
Now that i put the hoses back it seems fine or better at least u revering to taking the cat apart?
Old Aug 29, 2011 | 07:07 PM
Hockeyman's Avatar
It shouldn't have done any damage, but if you're seeing white smoke (before and after you switched hoses) then you probably have a far worse problem.
Old Aug 29, 2011 | 07:12 PM
Elusive's Avatar
Its not smoking all the time i havent seen it just today when the hoses were wrong!
Old Aug 29, 2011 | 07:21 PM
DubDub's Avatar
how many miles are on your car? and have you changed your oil lately...
Old Aug 29, 2011 | 07:24 PM
Elusive's Avatar
its almost due 73000 on it, it didnt smoke that I know of until the hose was wrong!!! It was like suffocating the supercharger.
Old Aug 29, 2011 | 07:36 PM
DubDub's Avatar
check your oil, and see if it looks normal. but is it smoking since you've fixed the lines?
Old Aug 29, 2011 | 07:42 PM
Elusive's Avatar
it didnt smoke all the time my friend said when i turned and got on it it smoked.. Will check and see if its smoking real fast since its been sitting!!
Old Aug 29, 2011 | 07:46 PM
Elusive's Avatar
It isnt smoking now just checked but of course its not under load. Kinda smells like gas though when u get on it..
Old Aug 29, 2011 | 08:54 PM
dumpleRL's Avatar
what's your plug gap
Old Aug 29, 2011 | 09:31 PM
Elusive's Avatar
I put it a .40 im stock except air box mod and the miss started after it i think!!
Old Aug 29, 2011 | 11:05 PM
Hockeyman's Avatar
that's too big of a gap, the miss is probably spark blow out.
Old Aug 29, 2011 | 11:23 PM
Boosted05's Avatar
gap to .035.
Old Aug 30, 2011 | 08:43 PM
Elusive's Avatar
Well today on my way home from work on the interstate when the care was under load it didnt seem like it had much power and was hunching when i was in boost.. came home and re gapped my plugs and wow it woke the car up Now if it will just continue to run like this!! One more question the car ran fine until i did a brake job and the airbox mod.. could the air box mod foul or hurt my plugs? Thanks again guys this forum rocks!
Old Aug 30, 2011 | 09:49 PM
Hockeyman's Avatar
air box mod will have nothing to due with fouled plugs
Old Aug 31, 2011 | 06:57 PM
Elusive's Avatar
So today I have that same problem again. Last night after gaping the plugs she felt great.. Today the problem is back.. It seems to run fine until i go into boost at which point it seems to fall on its face. It feels as if something is holding the car back and sometimes hunches a little!! I need help guys, I am starting to lose sleep over this... thanks again. I did not have these problems until I did the air box mod and change the front rotors and brakes on the car... When me and my friend did the bled the brakes the car tried to die is this normal? I still have a leaky caliper also that is letting some air in the lines.. any help would be great!!!
Old Aug 31, 2011 | 07:26 PM
Elusive's Avatar
From what I am reading could the airbox mod be throwing my fuel trims really far out of whack? Should I just put the stock box back on and if so will it self correct the fuel trims? Thanks guys
Old Aug 31, 2011 | 07:55 PM
Elusive's Avatar
Anyone??
Old Sep 1, 2011 | 07:46 AM
Staged07SS's Avatar
Administrator
Administrator
It will mess with your trims slightly, but nothing to cause the issues you are experiencing. The LSJ's MAF sensor is no where near as picky as the LNF's.
Ever since the SS/TC's came out that's all I hear about anymore.... fuel trims, fuel trims, fuel trims.
Your trims are prob slightly positive due to the increased airflow from the airbox mod, but you should be fine. Like others have said, try regapping your plugs & check your oil.
Old Sep 1, 2011 | 08:09 AM
Elusive's Avatar
Regapped plugs and it ran better that night the next day same issue.. plugs were way off when i regapped them.
learcpt
Jan 7, 2011 11:48 PM
Brnaubrey
Jun 28, 2006 02:47 PM
