ZZP phenolic IM spacer
Old Jul 30, 2011 | 02:32 AM
rivaladore's Avatar
Wow best $100 I ever spent. I know ait2's are subjective to this and that but whatever I'll post my experience. Usually on a 90 degree day I would see a 20-25 degree difference from iat2 to ait1 cruising on the highway, with mods in my sig without spacer, but today they were about 14-18 degrees cruising on the highway after I installed the spacer keep in mind this is when it hot as ***** outside. The biggest difference is sitting at idle and cruising around town, ait2's stay so much lower. Haven't had a chance to see what they are at night when it's cooler out. I can't believe this mod isn't more publicized for the ss sc crowd.
I'm sorry BYT I know you're coming out with a batch of them but I'm an impatient **** plus I had to order some other stuff from them. Without a doubt I know yours will perform just as well.
UPDATE for night driving results.....cruising home on the highway tonight I averaged 7-11 degrees over ait1. Here's some video I just took.
http://www.youtube.com/watch?v=WNdp5Ifc6Fc
Old Jul 30, 2011 | 02:36 AM
Omnigear's Avatar
i wonder if the tvs will pose a problem due to the bigger size.
or even the bigger blowers.
Old Jul 30, 2011 | 02:41 AM
rivaladore's Avatar
I saw a post on gmsprtcompct.net......spelt wrong hoping this site doesn't filter it........that rodimusprime made about having a Im spacer, supercharger spacer, tvs, and had to run a 2.8 or 2.9 pulley in order to clear the front on the car
I plan on running a tvs in the next few months and will be doing some research so I can still run the Im spacer
Old Jul 30, 2011 | 03:34 AM
hungryhip-ccp's Avatar
I just got a i/m spacer for my lsj. It worked so good I am amazed at the difference in heatsoak from before and after install.
Old Jul 30, 2011 | 03:50 AM
RonSS's Avatar
I had a couple of those machined for my Quad 4 engines 10 years ago. They were quite effective just to the touch. I never had a method to measure the IAT though.
Does it mess with the belt tension at all?
How thick is it?
Ron
Old Jul 30, 2011 | 10:27 AM
rivaladore's Avatar
How thick is it?
Ron
I didn't measure it but if I had to guess I'd say around 1/4 inch maybe, could be wrong though. With my stock tensioner, 2.8 pulley and stage 2 belt everything still fit fine. Only thing is the bolt for the lower intake manifold bracket didn't line up anymore so right now the bolt isn't in, no problems but ive been meaning to ask zzp about it
Old Jul 30, 2011 | 11:33 AM
Flatgod's Avatar
I have the IM spacer with TVS and had no clearance issues even with stock pulley. As far as the lower IM bracket the spacer kit should have come with three aluminium washers approx 1/4 inch thick that you put behind the bracket to space it out as well.
Old Jul 30, 2011 | 11:40 AM
zrated89's Avatar
subd may have to get this for my tvs
Old Jul 30, 2011 | 11:48 AM
Omnigear's Avatar
go go guinea pig from badnews ^_^
Old Jul 30, 2011 | 12:02 PM
rivaladore's Avatar
The website said those spacers are for the intercooler pump bracket not intake manifold bracket so i didnt put them in yet because I was pressed for time. I guess it's a typo. Dammit I gotta tear everything apart again
Old Jul 30, 2011 | 01:40 PM
zrated89's Avatar
joe was gona try it a while ago but the ole man talked him out of it
Old Jul 30, 2011 | 03:10 PM
RooTBeeR's Avatar
i actually totally forgot about this...may have to see what byt comes up with
Old Jul 30, 2011 | 05:00 PM
Omnigear's Avatar
Old Jul 31, 2011 | 11:03 PM
Flatgod's Avatar
Ya the intercooler pump bracket needs to be bumped out so the bolt under the LIM lines up.
Old Jul 31, 2011 | 11:17 PM
rivaladore's Avatar
Yea I'll be doing that sometime this week, is it bad to be driving around without the bolt in, haven't had any problems so far
Old Aug 1, 2011 | 12:13 AM
rivaladore's Avatar
Found this photo online and thought I'd share so people dont run into the same problem. The 3 spacers bump out this bracket so that bolt will thread into the intake manifold. Ill be doing that tomorrow if I have time.
Old Aug 1, 2011 | 12:21 AM
SuperSport4's Avatar
been reading a lot of good stuff about this product..... next mod!!
Old Aug 1, 2011 | 12:43 AM
Omnigear's Avatar
meh i dont even have mine bolted for that part =p
Old Aug 1, 2011 | 12:53 AM
rivaladore's Avatar
Right now I don't either and everything seems fine but I don't feel comfortable leaving stuff undone. How long have you been running your car with out that bolt
Old Aug 1, 2011 | 01:15 AM
Omnigear's Avatar
3yrs now, and i recently checked the LIM when i put my tvs on
Old Aug 1, 2011 | 11:43 AM
Flatgod's Avatar
You've got *****. I wouldn't run without it esp with the spacer in there. Because the SS bolts for the spacer are longer and the mani is gapped so to speak from the head by the spacer it allows more bolt to stretch. There would be tons of torque on those bolt when the supercharger is under load. The bottom bolt holds up the mani without that bolt the mani is just hanging off the head.
Old Aug 2, 2011 | 01:18 AM
rivaladore's Avatar
Just added a video to the first post, finally got to see how well the im spacer works on a summer night. I was averaging about 7-11 degrees from ait1 to ait2
Old Aug 2, 2011 | 01:24 AM
RooTBeeR's Avatar
wicked
Old Aug 2, 2011 | 01:26 AM
rivaladore's Avatar
wicked
I know right...why the **** isn't this mod more popular
Old Aug 2, 2011 | 12:44 PM
zrated89's Avatar
because like the griffin people that buy them arent putting up data for comparison like you are. Everyone here wont buy anything until its been proven so rep points for you sir.
