ZZP phenolic IM spacer
The stock is the expensive part on those. Heck I can only find laminated phenolic with cotton in between and that is only rated to the low 200*F, where as pure phenolic is in the high 300*F range. I've found a couple other plastics that should work but one costs 80 bucks just to get a piece big enough make the plate from.
I would say, 45 minutes to take it apart and an hour to get it back together. Or if you've done it a few times I would say under an hour and a half. I can have the blower off so fast now because I have to remove it to change the oil (dont bitch at me, I have a power steering pump right above the oil filter).
You may be able to do it the way GM tells the blown j-bodys to do it. Shove a 1/2" torque wrench in between the head and the bottom of the motor mount and push down on the tensioner arm.
I don't have one, nor am I looking to purchase one. I just want to learn about it a bit.
That's the way I do it.
I'm thinking about purchasing the belt tension tool from pulley boys. It will make the job a little easier.
Did you not watch the video in my first post?
tq wrench? or breaker bar? breaker bar dont fit on my car i needed to us a serpentine belt bar.
If there is a GB I will buy one. I already need to buy the upgraded shifter bracket and trans fluid from ZZP, I'd like to order everything I need to reduce money spent on shipping for different orders.
I think I need a new tensioner shock thingy, mine wont move at all. I took it to the dealer a few weeks after I got it and they said that is how it's supposed to be....umm no. Looks like I migh thave another part to order when I order the throttle body spacer for my meth.
Um, you should only be monitoring your iat2's. Thats what important, the iat1 really doesnt tell you as a tuner ****. Your timing and other iat corrections should all be off the iat2, so get that fixed.
