ZZP phenolic IM spacer
Old Aug 4, 2011 | 01:41 PM
  #51
nizzle's Avatar
nice
Old Aug 4, 2011 | 02:43 PM
  #52
RooTBeeR's Avatar
I've heard of this causing issues with the dipstick.
Did you have to bend the dipstick, or did you find any issues with fitment on your install?
Originally Posted by nizzle
So no issues with using this in combination with a TVS then? The only issue is the dipstick?
meh, i already bent my dipstick so that i could get to it with he tvs, doubt the spacer will affect that
Old Aug 4, 2011 | 03:07 PM
  #53
Powell Race Parts's Avatar
X2 and with single pass IM even more so. lol
Old Aug 4, 2011 | 06:10 PM
  #54
Leafydialupking's Avatar
The stock is the expensive part on those. Heck I can only find laminated phenolic with cotton in between and that is only rated to the low 200*F, where as pure phenolic is in the high 300*F range. I've found a couple other plastics that should work but one costs 80 bucks just to get a piece big enough make the plate from.
Old Aug 4, 2011 | 06:28 PM
  #55
Moore2877's Avatar
Im in for a group buy. Anyone know how long the installation is for a one man job?
Old Aug 4, 2011 | 06:30 PM
  #56
I would say, 45 minutes to take it apart and an hour to get it back together. Or if you've done it a few times I would say under an hour and a half. I can have the blower off so fast now because I have to remove it to change the oil (dont bitch at me, I have a power steering pump right above the oil filter).
Old Aug 4, 2011 | 06:50 PM
  #57
Omnigear's Avatar
meh only pain for me is takin moving the belt tensioner. i have worn out the lip to hook the 15mm that it slips form time to time.
Old Aug 4, 2011 | 06:53 PM
  #58
You may be able to do it the way GM tells the blown j-bodys to do it. Shove a 1/2" torque wrench in between the head and the bottom of the motor mount and push down on the tensioner arm.
Old Aug 4, 2011 | 07:41 PM
  #59
chris88z24's Avatar
I've heard of this not working and being a complete waste of money.
Old Aug 5, 2011 | 07:18 AM
  #60
Staged07SS's Avatar
Administrator
Administrator
I don't have one, nor am I looking to purchase one. I just want to learn about it a bit.
That's the way I do it.
I'm thinking about purchasing the belt tension tool from pulley boys. It will make the job a little easier.
Old Aug 5, 2011 | 10:54 AM
  #61
rivaladore's Avatar
Thanks man tried that last night and it worked. Didn't use a torque wrench, used a 1/2" extension that's about a foot and a half long. Gonna try to take a video of it later and post it in the how to section. It's a piece of cake to remove the belt now
Did you not watch the video in my first post?
Old Aug 5, 2011 | 10:57 AM
  #62
Omnigear's Avatar
tq wrench? or breaker bar? breaker bar dont fit on my car i needed to us a serpentine belt bar.
Old Aug 5, 2011 | 07:13 PM
  #63
I meant breaker bar. Thats twice I've said torque wrench when meaning breaker bar.
Old Aug 5, 2011 | 07:17 PM
  #64
Omnigear's Avatar
idk how you guys are fitting breaker bars but im using a 3/8's drive and it wont fit, unless i go through the wheel well?
Old Aug 5, 2011 | 07:20 PM
  #65
Stand in front of the car, align the breaker bar with the belt, and shove her in and push straight down towards the sc pulley. I'll make a video later/tomorrow.
Old Aug 6, 2011 | 08:42 AM
  #66
zrated89's Avatar
prybar works the best
Old Aug 6, 2011 | 01:17 PM
  #67
http://www.youtube.com/watch?v=8rGRfWIxARk
Old Aug 6, 2011 | 01:41 PM
  #68
xxxxsh4d0wxxxx's Avatar
If there is a GB I will buy one. I already need to buy the upgraded shifter bracket and trans fluid from ZZP, I'd like to order everything I need to reduce money spent on shipping for different orders.
Old Aug 6, 2011 | 04:30 PM
  #69
Omnigear's Avatar
cameraman phail.... i couldnt see where you rest the breaker bar >_<
Old Aug 6, 2011 | 04:40 PM
  #70
Derp
Old Aug 6, 2011 | 08:09 PM
  #71
rivaladore's Avatar
Holy moly picture size. Yea that's pretty much how you do it on a lsj. Stick one end in the motor mount, line it up over the pullley tensioner and then push down.
Old Aug 7, 2011 | 08:01 AM
  #72
klloyd's Avatar
I think I need a new tensioner shock thingy, mine wont move at all. I took it to the dealer a few weeks after I got it and they said that is how it's supposed to be....umm no. Looks like I migh thave another part to order when I order the throttle body spacer for my meth.
Old Aug 7, 2011 | 09:06 AM
  #73
hhrfreek's Avatar
I am ordering the ZZP spacer kit next week along with dual pass. I have no clue what my iat2's are since I can't monitor them(2.4lsc), but those mods should help me out.
Old Aug 7, 2011 | 01:42 PM
  #74
RooTBeeR's Avatar
invest in an interceptor or 2
Old Aug 7, 2011 | 08:44 PM
  #75
Um, you should only be monitoring your iat2's. Thats what important, the iat1 really doesnt tell you as a tuner ****. Your timing and other iat corrections should all be off the iat2, so get that fixed.
