Boost gauge bad? Or is it something else?
Old May 30, 2008 | 09:42 PM
Tennpenn83's Avatar
Hey ya'll got something for ya.
Running a 2.9" pulley, monitoring boost via mechanical Phantom II Autometer boost/vacuum gauge.
I have always observed around 14-15 psi (which I always thought was kinda low for a 2.9")
Saw the other day I was only boosting around 11-12 psi. (Gauge is only about 2 months old). Just being the paranoid **** that I am, I took off the supercharger, intake manifold, inspected any related boost/vacuum lines and seals of everything. Gaskets for both the s/c to i/m and the i/m to head were inspected and turned out to be ok. Inspected the intercooler endplate seal and it's ok. Played with the boost bypass actuator (before and after teardown/re-install) and it's working fine. THERE IS ABSOLUTELY NO PROBLEM WITH THE INTAKE/BOOST SYSTEM.
For reference, when the engine is off and there is no boost/vacuum, the gauge has always read around 3-4 Hg on the vacuum side. Never has been exactly zero. Could this be the boost gauge itself being a factory defect? What are other people boosting on a 2.9" pulley?
Please keep in mind that I have a ZZP mid-length header/ 3" downpipe with 2.5" Hi-flow cat on so I assume that I will drop just a psi or so in boost because of better airflow, am I right?
Old May 30, 2008 | 09:46 PM
KillerBee's Avatar
what rpms you hitting at 12psi
Old May 30, 2008 | 09:51 PM
Tennpenn83's Avatar
Under WOT I hit around 11-12psi from 4k up to redline, but it's very inconsistent. 1st gear WOT actually makes the gauge flutter all over the place, and it's impossible to tell any kind of boost in 1st gear. 2nd and up usually only hit 11-12 if I am lucky.
Old May 30, 2008 | 09:56 PM
KillerBee's Avatar
just thought of something which pully you running? If its nates then there is a possiblity that if could be slipping since its so light weight. your tensioner might not be working that great i noticed this when i had my nates 2.9. since you have a 3" downpipe you will lose some boost but not power due to the fact more air can escape with a bigger downpipe unless you noticed a lot of powerloss i would not be to worries about it
Old May 30, 2008 | 10:01 PM
Tennpenn83's Avatar
It's a Smoothflow 2.9" polished aluminum 3 ounce pulley. My tensioner is fine and my belt is not slipping. Both are regularly inspected by myself. Just worked with the tensioner today when removing the belt for when I inspected EVERYthing else related to the intake manifold.
If it were the pulley being lightweight, then it would have always been around 12 psi. A month ago I could consistantly hit 15.
Old May 30, 2008 | 10:04 PM
KillerBee's Avatar
ok so thats not it. Only other thing i can think of is the wastegate going bad or the gauge is messed up. Now is the gauge an aftermarket or stock one?
Old May 30, 2008 | 10:08 PM
Tennpenn83's Avatar
Aftermarket Autometer Phantom II mechanical 30psi boost gauge.
Old May 30, 2008 | 10:09 PM
KillerBee's Avatar
now did you have any issues with your stock one? Or did you just want a new one? If you have your stock one put it back on and see how it goes.
Old May 30, 2008 | 10:11 PM
Tennpenn83's Avatar
Ion Redlines did not get a stock boost gauge unless you got the G85 package (LSD, gunmetal wheels, boost gauge, ladder tach lights)
Old May 31, 2008 | 10:48 AM
Tennpenn83's Avatar
Bump for anyone else
What is anyone else seeing boost-wise with a 2.9" pulley?
Old May 31, 2008 | 11:07 AM
DangotBoost's Avatar
I see 16-17psi on nate's 2.9 with stock DP. About 15-16 with the CA catted DP. Hope this helps!
Old Jun 2, 2008 | 06:19 PM
Tennpenn83's Avatar
Alright guys here's the dyno from earlier today:
As you can see I'm making decent power up to about 5500 rpm where the a/f ratio drops from 13 or so to 12 and then keeps dropping all the way to 6300 rpms, where it's so rich, the tailpipe wideband used can't even read it. At this point, the dyno was cut short at 6700 rpm (300 shy of redline) because the tech didn't want to damage my engine.
The solid slanted HP graph line would have kept going, probably all the way up to around 250 or higher is the a/f ratio had not dropped.
Old Jun 2, 2008 | 06:26 PM
06_SS_S/C's Avatar
if it is a mechanical gauge, you should be seeing ZERO on the gauge when the car is off. sounds like its an issue with the gauge to me.
run up to your local autoparts store and buy another one real quick to test. you can always take it back when you're done, at least that is how the stores are out here
Old Jun 2, 2008 | 06:51 PM
Tennpenn83's Avatar
read my last post... it's not the gauge
Old Jun 2, 2008 | 06:58 PM
06_SS_S/C's Avatar
regardless of what the dyno showed, the gauge should show 0 when the car is off. if its not, there is a problem with the gauge. im not saying there aren't other problems with your car.
Old Jun 2, 2008 | 07:23 PM
Tennpenn83's Avatar
gauge will be replaced soon. unless anyone else knows how to adjust a phantom II autometer gauge
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
