boost for a lsj supercharged?
Hey guy I'm new to the cobalt world I picked up my 07 ss/sc from the dealer Friday what kind of boost should it be running? Anything you can tell me about ss's? Its all stock besides a cold air intake borla exhaust and coil overs
provided the pulley is stock (black pulley, pressed on no bolts on it) you should be pushing around 11-12 psi at max
make sure your i.c. pump is running. (most by now have failed) you will see coolant moving through the little fillerneck in front of the supercharger if its working. if theres no fluid fill it till there is fluid. if its full but not moving replace the pump.
