Boost Pressure?
Old Apr 26, 2009 | 01:25 AM
BLACK/-\SS/SC's Avatar
Exclamation Boost Pressure?
I have a 2006 ss/sc and I was wondering where my boost pressure should stand. I wasn't sure if it is suppose to be. It tops its boost between the 0 and 5. So i'm guessing 2.5? I'm not truly sure how to read my boost gauge. Any help where it should be?
Old Apr 26, 2009 | 01:28 AM
nicksredline's Avatar
wow ... umm u should read ur boost gauge and i would say it go's to right around 12-15 ish depending on elevation but i dont know about 5. do u have an aftermarket or the one that came in the car? if its aftermarket u prob have it hooked up rong or its leaking. if its the stocker i would say eather ur gauge is rilly off or ur car is crazy! ( does it seem to run fine/ normal) also u read ur boost gauge at full throttle ( usualy in gear.. the more load the more boost u will build... to a point) but u read where the needle spikes out on the boost side( dont worry about the vacume side.
Old Apr 27, 2009 | 11:39 AM
Yea dude my car is stock, but the gauge doesn't past 5 WTF? I recently had my guage replaced back in october last year, cuz it gave out. It was cover under warranty and so they fixed it. I bought the car used and it was always at under 5psi. So I figured maybe that is how its suppose to be. Even after I had rhe gauge fixed it stayed like that. I'm going to see wat I can do, maybe myself or dealer wise. Thanks bro. Also any suggestions?
Old Apr 27, 2009 | 03:21 PM
Redefined1's Avatar
please check your filter. possible clogging.
Old Apr 27, 2009 | 03:23 PM
BLAZIN07SS's Avatar
I'm too JDM for you
something doesnt sound right with the boost bypass solenoid
Old Apr 27, 2009 | 03:32 PM
coopn8r's Avatar
I'd take that thing into the dealership and be like.. WTF did you do!
Old Apr 30, 2009 | 01:18 PM
Yea i called today, and they want to charge me to look under the hood. I'm jus going to do it myself,first i'll try the air filter if not that, the wastegate.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
