Boost problem
Old Apr 1, 2008 | 10:57 PM
fastscion's Avatar
Boost problem
Hi
I've a 2006 S/C Cobalt SS and have upgraded it to the stage 3 kit from CA which should increase the boost level to 18 PSI. (+65HP PCM retune 2.7 pulley shorter GM belt 42 lbs injectors)
http://cobalt-addiction.com/performance.htm
after I installed the kit everything worked fine and I got a nice response from the car. Now 2 weeks later the car is not boosting 18PSI anymore but only 15 PSI does anybody have an idea of what the problem could be...?
thanks in advance
Old Apr 1, 2008 | 11:02 PM
tREBs's Avatar
sounds like a boost leak somewhere.. do u have a mechanical boost gauge?
Old Apr 2, 2008 | 08:19 AM
fastscion's Avatar
No I Don't
I got a response that is telling me
"I would bet about 90% that the problem is the supercharger bypass vacuum solenoid"
which solenoid is the bypass vacuum solenoid?
Old Apr 2, 2008 | 08:45 AM
Z06vettespd's Avatar
Could be the 42lb injectors are restricting the psi?? maybe??
Old Apr 2, 2008 | 10:27 AM
Mattman6's Avatar
are you seriously running 42's on a 2.7? Get a bigger pulley on there ASAP you are working those injectors hard.
Old Apr 2, 2008 | 03:13 PM
C0baltWithM0ds's Avatar
im running a 2.7 on 42#s never had a problem its been over a year
Old Apr 2, 2008 | 03:15 PM
SSCobalt~SSZ24's Avatar
doesnt CA sell the stage 3 kit with a 2.7 and 42s? pretty sure they do
Old Apr 2, 2008 | 05:06 PM
fastscion's Avatar
Yes they do I bought it like it is with the 2.7 and 42lb injectors
Stage #3 : 2.7 ZZP Interchangeable Pulley system , 1 step colder ngk IRIDIUM spark plugs , GM shortened belt , 42# Lucas Injectors , Injector Wiring Harness, Stage #3 Retune ... Est. 65 Hp over stock - 18 psi boost
Stage #3 Your Price: $579.99 USD
did you change your tensioner for the adjustable tensioner maybe...?
Old Apr 2, 2008 | 05:30 PM
the pulley size is a 2.79 i believe
Old May 5, 2008 | 09:52 PM
fastscion's Avatar
thanks for all your help and replies on my post
the problem of my car was the boost gauge which was faulty
I changed it and wow.... again like it should
Old May 5, 2008 | 11:01 PM
INFE's Avatar
i would be carefull with those 42s and a 2.7. The **** is going to go BOOM soon!!!!!!
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
