boost problems?
Old Jul 18, 2006 | 10:21 AM
rickyw's Avatar
boost problems?
Has anyone not been seeing 12.5 psi? ive been driving the car for about a week now and have never once recall seeing the full boost. Should i take it to the dealer and ask them whats up? I checked the gauge at ignition and it sits right at 0.
On a nother note, Has anyone had bouncing needles on there main gauges after shut off? when i shut the car down sometimes the needles will bounce up and down a couple of cm for 2-5 mins?
Old Jul 18, 2006 | 10:29 AM
CTCOBALTSSS's Avatar
You have to remember that you won't see 12.5 psi untill you get to the higher rpm range like 6,000 to 6,800 or so. Most people punch it at 3,000 or 4,000 rpm and expect 12psi.
As far as needles bouncing, I have no idea.
Old Jul 18, 2006 | 10:31 AM
IMADreamer's Avatar
I have no problems getting 12psi. Are you sure you are at WOT and high RPMs?
I don't have bouncing needles sorry.
Old Jul 18, 2006 | 10:35 AM
firesting's Avatar
At about 4-5k rpm i hit about 10.8 Psi. I haven't testing near redline Psi, but I will soon and post. I am bone stock as performance goes, for now anyways hehe... My boost gauge needle is off by 5, so it shows 80 when its really 75, I'll go get that fixed lol.
As for needles bouncing, it happened to me, well I only saw it happen once. It's normal, don't worry about it. I posted something about that not too long ago, if I find the post, i'll give the link!
EDIT: Here's the link for when I posted that gauge "problem": https://www.cobaltss.net/forums/problems-service-maintenance-69/clutch-shifting-analogue-needles-gauges-22348/
Old Jul 18, 2006 | 10:47 AM
rickyw's Avatar
thats the problem i am at 6-7k rage and still bearly see 10.5 at the most maybe 11. the gear i do this in is 2nd ill check today on way back home. I was on a straight road the other day stopped and took it in 2nd gear all the way up to redline and didnt even hit 12psi however i will check it again just in case i missed something. The needles bouncing is driving me nuts cause they just look like there studdering
Old Jul 18, 2006 | 10:50 AM
Try 3rd gear bro.
Old Jul 18, 2006 | 11:41 AM
Posey204's Avatar
I have seen my needles bounce a few times after shut off. It is kinda wierd.
Old Jul 18, 2006 | 01:54 PM
rickyw's Avatar
ok ill try third gear and see if i get the full 12 psi
Old Jul 18, 2006 | 02:07 PM
cavy9psi's Avatar
yea 3rd gear you might see full boost cuz of the load. dont forget supercharger is all by pulley for boost so boost really cant get effected by the computer unless the car runs like a bag but you shouldnt have any problems yet you just need higher rpms and a harder gear...1st and 2nd just kinda get ripped through and are torque which wouldnt alow full boost...
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
