boost problems on ss/sc help
Old Jan 25, 2011 | 03:00 AM
kawategra98's Avatar
i have a 2005 ss/sc intense stage 3 engine is from a 2008 with 11,000 miles on it. story is when i put the new to me engine in and put my intense stage 3 kit on the car ran like a freakin raped ape riding a scalded dog. I dont drive the car often maybe 300 miles a month, cause im a trucker, well now im only getting 5 psi boost when i get on it and alot of fuel smoke, you tech guys, what gives?? is it a bad bypass solenoid??? or what do you guys think it is help me out thx much appreciated.
Old Jan 25, 2011 | 12:56 PM
Old Jan 25, 2011 | 01:43 PM
xxxxsh4d0wxxxx's Avatar
2008 SS motor is an LNF, not an LSJ.
That can't be right.
Old Jan 25, 2011 | 01:57 PM
user 72239's Avatar
yeah, if its from a 2008 you put a LNF motor in it not a LSJ.
Old Jan 25, 2011 | 02:17 PM
jonathan923's Avatar
2008 motor what??lol confused its gotta be an lsj..
Old Jan 25, 2011 | 11:53 PM
ok i goofed sorry it must be an 07 then sorry can anyone help the point at hand?????
Old Jan 26, 2011 | 12:02 AM
not too much aware of intense stuff but does that kit comes with a tuned pcm or something?
Old Jan 26, 2011 | 12:04 AM
if your seen fuel smoke meaning black smoke then you must be running very rich and need a tune asap.
Old Jan 26, 2011 | 10:23 AM
red06SC's Avatar
Intense < there's your problem
Also, Duke.
It was probably cause by Duke.
Old Jan 26, 2011 | 12:16 PM
Caused by Duke, lol how old are we??? ok well thx for the guys who tried to answer in a mature manner this site is not what it use to be, why did i just renew my subscription......
Old Jan 26, 2011 | 01:00 PM
SCcobaltSS's Avatar
I have heard bad things about intense so you could use a custom tune but I dont think it is entirely the problem. You were running 12-16 psi (not sure what pulley you have) before now all of a sudden 5psi?
Old Jan 26, 2011 | 01:04 PM
red06SC's Avatar
they must have flopped on your bypass actuator or something, perhaps laettner stomped it?
Old Jan 26, 2011 | 02:07 PM
stonny9's Avatar
Bad bypass solenoid might be. When I put a smaller pulley without a tune and the bypass still hooked up. It would drop to about 5psi and fall on its face. I disconnected the bypass solenoid and never had the problem and had/have no ill effects.
Also you can put the lnf 08-10 aka GenII block in an lsj 05-07. You basically just have to put on the lsj head, intake and exhaust. The lnf has stronger sleeves and some other stuff that I cant remember.
Old Jan 26, 2011 | 02:17 PM
alleycat58's Avatar
Any CELs or DIC messages???? If you can, I'd have someone log it. Black smoke out the back = pig rich. Definitely agree it could be the solenoid. Have you pulled the plugs to see what they look like yet?
Old Jan 30, 2011 | 08:35 AM
i agree it must be the solenoid because i put a manual controller in and run it about 10 psi and it runs good pulls hard but now it goes up to 10 psi and bleeds back down to 5 psi like i got a vacuum leak now. but to answer your question no cel,s or dic and the plugs show sign of richness
Old Jan 30, 2011 | 08:51 AM
BLAZIN07SS's Avatar
I'm too JDM for you
there is no reason to put a manual controller on it. it's all dictated by the pulley
Old Jan 30, 2011 | 09:29 AM
mrbelvedere's Avatar
he is correct the intense tunes arent garbage just realy aggressive
Old Feb 3, 2011 | 06:08 PM
yea i know this i put it in line in place of boost controller so not to over do it at w.o.t. if i just do the boost bypass it goes into limp mode
Old Oct 26, 2011 | 07:57 PM
bump, i have replaced the bypass solenoid, and valve, still getting only 5 psi out of it, but i noticed that during the warmer months it ran fine, but now that it is cooler outside it is starting its b.s. again, idk wtf is wrong with it, and now i get a lean cel but im blowing raw gas out the ass end, what gives tech guys help me out please thx.
Old Oct 26, 2011 | 08:26 PM
the reason the car is spitting fuel out the back is it thinks it lean so it keeps richening up sounds like you need to take it to the dealer or do a boost leak test and find your leak
Old Oct 27, 2011 | 12:37 PM
SCcobaltSS's Avatar
You sure its raw fuel and not condensation build up because its cooler out?
Are you driving a little bit when you try your WOT run? Is it knocking?
There are limiters on the tune that could drop the PSI to try to save the motor. Just throwing things out.
Old Oct 27, 2011 | 12:44 PM
Whitnith's Avatar
As said before, Intense is garbage.
Get a different tune. I would say just about any other HP Tuners tune out there is going to be better, and would probably clear up the fuel issues.
Old Oct 27, 2011 | 04:32 PM
arellano201's Avatar
Yea I'm having the same issue but mine strictly hits 3psi and just stays there when i punch it. It doesn't bleed down since it just hits the 3psi wall. I'm gonna check my BPV and for any leaks.
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
