Boost Question
Old Dec 25, 2007 | 02:22 PM
Inferno's Avatar
Boost Question
how may psi should i expect with a stage 2 kit qand a 2.9" pulley vs just satge 2 pulley.
Old Dec 25, 2007 | 02:27 PM
Jared B's Avatar
maybe 15 or 16 for both
Old Dec 25, 2007 | 02:30 PM
srowler9's Avatar
15 stage 2
16 2.9
Old Dec 25, 2007 | 02:35 PM
Jared B's Avatar
all cars are different i have see Stage 2 a 17psi and 2.8 at 16.
i would even waste my money on stage 2. i saw one dyno and it was at 220
Old Dec 25, 2007 | 02:37 PM
Inferno's Avatar
do run a custom set up then? if so what do u run?.
Old Dec 25, 2007 | 02:40 PM
Johnny B's Avatar
i have hit 15.5 with my 2.9 on stage 2 flash and stage 2 pulley i hit 14.5 but with 2.9 and cooling mods i hit 17-18 psi!!! cooling the heaton is you best friend!!!
Jared B's Avatar
I have all this but i havent installed it yet. Kid i no has the same set that i have but no headers he dyno at 253 at 16psi.
2.8 pully w/ Hub, 60lbs injectors w/ Casper wire harness, Dual pass plate w/ Cobra H/E, Option B kit, ZZP Headers, ZZP Downpipe, Megan Catback, NGK plugs, AEM CAI.
Old Dec 25, 2007 | 02:41 PM
Inferno's Avatar
what cooling mods would u recomend? cobra h/c, meth ect.
Old Dec 25, 2007 | 02:42 PM
Jared B's Avatar
Daul pass plate option b kit cobra H/E
Old Dec 25, 2007 | 02:45 PM
Inferno's Avatar
is a daul pass plate hard to install? does it make a noticable difference by itself?.
Old Dec 25, 2007 | 02:47 PM
Jared B's Avatar
its hard to install u have to take off the superchager and the manifold to install it but it brings down ur temps. u will see a difference.
Old Dec 25, 2007 | 02:50 PM
Inferno's Avatar
thanks for the help dude.
Old Dec 25, 2007 | 02:52 PM
Super_SS's Avatar
im seeing 18psi+psi with 2.9,zzp downpipe
Old Dec 26, 2007 | 03:51 PM
Johnny B's Avatar
i like my meth injection set up!!!!
Old Dec 26, 2007 | 04:38 PM
CobaltSS 16's Avatar
Stage 2 = 15.5psi
2.9 = 16.5 psi
Or around there, those are what you should see at sea level. At higher altitudes you might see a little different. If it's colder (winter time) you might see 1 or 2 psi more for both.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
