Bought A TVS
Well I finally bought a TVS. Mods are badmab header, catted 3" zzp down pipe, custom 2.5" cat back, zzp 3" CAI, 60's, zzp s3 heat exchanger, pretty much just full bolt ons. With my M62 on a 2.7 I made 256whp. TVS with a 2.8 I made 321whp 277wtq.
Turbo Tim at ZZP did an awesome job tuning my car, ZZP FTW.
Now if you get rid of the 2.5" catback and swap it for a 3" catback, you should see a 12-15 WHP improvement at this HP level, which would bring you at 335WHP (probably about 400BHP when factored from this dyno).
I hope so. I wanna get 3" exhaust, meth, and 2.6" pulley soon.
Those are actually very high numbers for the setup you have on a Mustang dyno. Was that on the ZZP dyno? If yes, I believe they have a 6% difference to the Dynojet (to confirm with ZZP guys), which would put you at 335WHP/295WTQ ... just curious as most of the TVS dyno runs I have seen with a similar setup (posted on this site) are waaaaay lower than yours ... except for a few when they got combination of stuff like ported head, MI, fat exhaust, E-85 ...
Would you mind to confirm the following for us:
- Stock TB?
- Phenolic intake spacer?
- Which spark plugs/gap?
- Fuel octane?
- Stock head exhaust ports?
- Rev limiter setting?
- Degrees of ignition timing?
- IAT2 during the pull?
- Commanded AFR?
- Stock returnless fuel system?
- How many PSI of boost?
- ... and where your dyno numbers corrected (SAE)?
Thanks!
- Stock TB?
- Fuel octane?
- Commanded AFR?
Thanks!
Last edited by Jmc007; Oct 27, 2011 at 10:31 PM. Reason: Added question if dyno numbers are corrected + changed assumed percentage for difference to Dynojet.
I believe once u get that small on a pulley if you add meth it will help with the fueling though. either way i'm sure you will still need to go above and beyond 80# injectors though. plus it's still a cooling mod of sorts if you do a mixture.
Those are actually very high numbers for the setup you have on a Mustang dyno. Was that on the ZZP dyno? If yes, I believe they have a 9% difference to the Dynojet (to confirm with ZZP guys), which would put you at 350WHP/302WTQ ... just curious as most of the TVS dyno runs I have seen with a similar setup (posted on this site) are waaaaay lower than yours ... except for a few when they got combination of stuff like ported head, MI, fat exhaust, E-85 ...
- Stock TB?
- Fuel octane?
- Commanded AFR?
Thanks!
- Stock TB?
- Fuel octane?
- Commanded AFR?
Thanks!
- No spacer
- I believe NGK plugs with .34 gap iirc
- 93 octane
- Stock head
- 7200 Red line
- Cant remember how much timing, ill get ahold of tim and find out.
- End of dyno run IAT2's were 140ish, Only cooling mod is ZZP S3 H/E
- Commanded AFR I Cant remember for sure, I wanna say 11.8, but ill ask Tim.
- Stock fuel system, using 60# inj
- 23.7 PSI boost at redline
- Yes numbers were corrected, uncorrected was a little higher but i dont remember the numbers.
it allows you to go around bragging about your IAT2s like people with Meth injection like to do!
Personally, I don't care that IAT2s are lower on Meth injection cars vs E85 cars. I know E85 cars make more hp.
