Bought A TVS
Old Oct 17, 2011 | 08:32 PM
Jaredssbalt's Avatar
How much of a difference would a 2.6 pulley make? Anyone know?
Old Oct 17, 2011 | 09:03 PM
MarqueDo7BabyBalt's Avatar
dam..very nice!
Old Oct 17, 2011 | 09:07 PM
CobaltSS 16's Avatar
Awesome, I will be picking up a TVS eventually.
Old Oct 17, 2011 | 09:30 PM
carstedt's Avatar
a 2.6 ull feel the difference wont be lik omg but ull notice it....add E and water meth and then ull def notice it
Old Oct 22, 2011 | 12:52 PM
Boxxy's Avatar
What size Pulley do you have? Or does that matter with the TVS?
Old Oct 22, 2011 | 01:23 PM
TStone's Avatar
He's on a 2.8... and of course, lol pulley size always matters..
Old Oct 22, 2011 | 01:45 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
I have meth, need a tvs
need need need
2.7 or 2.6... that is the question..
Old Oct 22, 2011 | 01:47 PM
Jmc007's Avatar
Originally Posted by Jaredssbalt
Well I finally bought a TVS. Mods are badmab header, catted 3" zzp down pipe, custom 2.5" cat back, zzp 3" CAI, 60's, zzp s3 heat exchanger, pretty much just full bolt ons. With my M62 on a 2.7 I made 256whp. TVS with a 2.8 I made 321whp 277wtq. Turbo Tim at ZZP did an awesome job tuning my car, ZZP FTW.
Could we see a better quality picture please?
Old Oct 22, 2011 | 01:49 PM
Ill try to get a better one posted up soon, hopefully tonight.
Old Oct 22, 2011 | 02:24 PM
zrated89's Avatar
once i dial in my tvs with the 2.7 and 10gph nozzle ill post results. Im more wanting to see my drag times though with slips screw a dyno imo
Old Oct 23, 2011 | 12:55 AM
  #36
lxl_Th3_On3_lxl's Avatar
321 damn that's good. Zoomer from zzp said that 290 whp was max on a tvs
Old Oct 23, 2011 | 05:19 PM
  #37
Jmc007's Avatar
Now if you get rid of the 2.5" catback and swap it for a 3" catback, you should see a 12-15 WHP improvement at this HP level, which would bring you at 335WHP (probably about 400BHP when factored from this dyno).
Old Oct 23, 2011 | 11:04 PM
  #38
I hope so. I wanna get 3" exhaust, meth, and 2.6" pulley soon.
Old Oct 23, 2011 | 11:10 PM
  #39
sjc0013's Avatar
Window Licker
damn, great numbers, makes me really wanna get mine dyno'd
Old Oct 24, 2011 | 01:24 PM
  #40
ebristol's Avatar
Impressive.
Old Oct 25, 2011 | 11:29 PM
  #41
Jmc007's Avatar
Well it was a Mustang dyno right?
Old Oct 26, 2011 | 12:56 PM
  #42
Ya, mustang dyno. I will hopefully have better pic of graph up soon. Took a better pic just no comp to upload on.
Old Oct 26, 2011 | 02:44 PM
  #43
Jmc007's Avatar
Those are actually very high numbers for the setup you have on a Mustang dyno. Was that on the ZZP dyno? If yes, I believe they have a 6% difference to the Dynojet (to confirm with ZZP guys), which would put you at 335WHP/295WTQ ... just curious as most of the TVS dyno runs I have seen with a similar setup (posted on this site) are waaaaay lower than yours ... except for a few when they got combination of stuff like ported head, MI, fat exhaust, E-85 ...
Would you mind to confirm the following for us:
- Stock TB?
- Phenolic intake spacer?
- Which spark plugs/gap?
- Fuel octane?
- Stock head exhaust ports?
- Rev limiter setting?
- Degrees of ignition timing?
- IAT2 during the pull?
- Commanded AFR?
- Stock returnless fuel system?
- How many PSI of boost?
- ... and where your dyno numbers corrected (SAE)?
Thanks!
Last edited by Jmc007; Oct 27, 2011 at 10:31 PM. Reason: Added question if dyno numbers are corrected + changed assumed percentage for difference to Dynojet.
Old Oct 26, 2011 | 03:07 PM
  #44
carstedt's Avatar
u wont regret a 2.6 jus get a good solid tune on it...e85 and meth make it alot better
Old Oct 26, 2011 | 04:43 PM
  #45
mrbelvedere's Avatar
you dont need meth with e85
Old Oct 26, 2011 | 06:25 PM
  #46
N1ckateen's Avatar
I believe once u get that small on a pulley if you add meth it will help with the fueling though. either way i'm sure you will still need to go above and beyond 80# injectors though. plus it's still a cooling mod of sorts if you do a mixture.
Old Oct 26, 2011 | 07:18 PM
  #47
Those are actually very high numbers for the setup you have on a Mustang dyno. Was that on the ZZP dyno? If yes, I believe they have a 9% difference to the Dynojet (to confirm with ZZP guys), which would put you at 350WHP/302WTQ ... just curious as most of the TVS dyno runs I have seen with a similar setup (posted on this site) are waaaaay lower than yours ... except for a few when they got combination of stuff like ported head, MI, fat exhaust, E-85 ...
- Stock TB?
- Fuel octane?
- Commanded AFR?
Thanks!
- Stock TB
- No spacer
- I believe NGK plugs with .34 gap iirc
- 93 octane
- Stock head
- 7200 Red line
- Cant remember how much timing, ill get ahold of tim and find out.
- End of dyno run IAT2's were 140ish, Only cooling mod is ZZP S3 H/E
- Commanded AFR I Cant remember for sure, I wanna say 11.8, but ill ask Tim.
- Stock fuel system, using 60# inj
- 23.7 PSI boost at redline
- Yes numbers were corrected, uncorrected was a little higher but i dont remember the numbers.
Old Oct 27, 2011 | 11:58 AM
  #48
ebristol's Avatar
AND
it allows you to go around bragging about your IAT2s like people with Meth injection like to do!
Personally, I don't care that IAT2s are lower on Meth injection cars vs E85 cars. I know E85 cars make more hp.
Old Oct 27, 2011 | 12:06 PM
  #49
Chevycobaltss3's Avatar
Now add meth and e lol and now u can brag who has the cooler combustion and iat2z
Old Oct 27, 2011 | 12:11 PM
  #50
zrated89's Avatar
wow those 60's must be screaming at you
