bypass valve
Old Dec 2, 2011 | 12:32 PM
ir2005's Avatar
bypass valve
Hey guys the redline is going in storage soon for winter I plan on rebuilding my sc and other things, I was on zzp's website looking at parts and came across this does anyone know if this does what the stock bypass valve does? its under eaton parts so im guessing its for the lsj. here is the link and input on this would be appreciated!
thanks
Brandon
- Bypass Valve # 14-01-01274
Old Dec 4, 2011 | 04:06 PM
ir2005's Avatar
No one knows what this is?
Old Dec 4, 2011 | 04:37 PM
insylem's Avatar
Prevents overboosting,
Is used to limit boost
Also is used when your not in boost to unload the supercharger so that
freespins and doesnt take away power
Old Dec 5, 2011 | 10:00 AM
ir2005's Avatar
so is this good to have? and does it replace the stock one? how does it even hook up?
Old Dec 5, 2011 | 10:09 AM
C_A_D88's Avatar
I think u would only buy that if yours is broken as a replacement
Old Dec 5, 2011 | 10:31 AM
mrbelvedere's Avatar
thanks
Brandon
is your blower making noise if it isent dont fix what isent broken the blower is good well past 100k
Old Dec 5, 2011 | 11:58 AM
insylem's Avatar
I think so too. Mine still works fine and ive never heard of anyone replacing it for a mod. Though I have heard of some people mucking with the hoses to trick the system into not reducing boost, but not sure exactly what they did.
Old Dec 5, 2011 | 12:07 PM
insylem's Avatar
Old Dec 5, 2011 | 07:23 PM
Sunburst's Avatar
^ This. I had to replace mine with the exact same part from zzp as one of the vacume hose tips broke. Its a direct replacement.
Old Dec 6, 2011 | 08:19 AM
ir2005's Avatar
So that replaces the stock one which is this
Eaton - EATON Bypass Valve #
This may be a stupid question because i know the lsj cant have a bov but is the zzp replacement one essentially that with the different springs and shims?
Old Dec 6, 2011 | 10:14 AM
SneakyMilo's Avatar
No. The ZZP is an exactly OEM replacement for your existing BPV. If your BPV is functioning correctly you do not need this.
Old Dec 6, 2011 | 10:18 AM
nismopowerdqg's Avatar
plus it looks cheap i wouldnt get it
Old Dec 6, 2011 | 07:01 PM
Sunburst's Avatar
IM sorry I was mistaken. The one I had to replace was the one you linked.
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Trav3480
Oct 1, 2015 08:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Trav3480
Sep 28, 2015 02:46 PM
