c02 bulb mounted in intercooler tank
had this idea of running a cry02 system with a blub mounted in my flow through tank to drop iats down
kinda like a killer chiller set up
any input
any input
Only concern would be how much heat transfer you can get with the available surface area of the bulb. Running it on the heat exhanger might yield better results just due to surface area.
I tried ice once **** melted so fast
Thinking of dry ice,
I figure liquid c02 in the dei kit will pull the heat towards it and drop the temp faster due to the fact that its such a temp difference between it and the coolant, kinda like refrigeration my coolant
put more ice in I would put more ice a little less water and switch it on a when the guy in front of you does a burnout then do it to it or shoot a 50shot through it that will probably work the best
