Cam ?
Cam ?
I plan on camming my car this spring. Im sure I will need vlaves, springs, and Im gunna get some pistons also. But I was wondering what kind of gains I should expect from cams...
without tuning, not much. with some tuning 10-25hp. if you get valve springs and valves, and pistons, may aswell go with gmpp neutral balance shafts or a balance shaft delete kit. then some cooling mods, 60lb injectors and go as small a pulley as you want as long as its tuned right.
well im puttin on a 2.7- 2.9 pully (cant decide), tune, injectors, and maybe the CA heat exchanger this spring... I was thinking about adding cam and springs sence it would be at the shop... will it be worth is. also is there anything im forgetting that might be required to buy for this setup?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
