cam comparison
Old Jul 31, 2008 | 03:32 PM
  #76
Witt's Avatar
Originally Posted by Action Jack
Are any of you guys who rev past 7200 have the GMPP neutral balance shafts? Basically I'm wondering if they are required or not. Because I'm wanting to set my rev limiter at 7500 with some cams and springs etc... and need to know if I should get the shafts or not.
I have them and they are only required for reving past 7500 rpm.
Old Jul 31, 2008 | 03:34 PM
  #77
freakta's Avatar
Originally Posted by qwikredline
#1 check with Alpha Jaguar or you Area, for springs i think there is some machine work to be done to the head to fit ferrera springs? You rev more, so the drop down to the next gear keeps you in the power band nice and fat. On the drag strip, as a general rule he who shifts last wins....but not always thats why its a general rule I hit the rev limiter in first (7k) doing burnouts ( I can do that now, no power hop)
well with my tiburon i used to run to 7200 at the track the engine didnt make power past 6400 or so... so when i started shifting right after it stopped making power i actually made it down the track a bit more quickly... but that was a totally diff car diff situation and well you gotta go with what you know. thats why i ask questions
Old Sep 15, 2008 | 11:50 AM
  #78
Area47's Avatar
Rent me! per hour
i think this needs to be stickied
Old Sep 15, 2008 | 02:35 PM
  #79
Raven SS's Avatar
post it on the right site and im sure it will...
Old Sep 15, 2008 | 03:55 PM
  #80
Area47's Avatar
Rent me! per hour
screw details.
Old Sep 15, 2008 | 06:58 PM
  #81
Raven SS's Avatar
Originally Posted by Area47
screw details.
edited..
Old Sep 15, 2008 | 09:40 PM
  #82
theneelster's Avatar
I want to see what the jbp triflows do but they apparently don't think actually verifying gains on a dyno ensures sales so...
Old Sep 27, 2008 | 09:29 PM
  #83
SSdan's Avatar
From a few friends experiences they did nothing except change the power band. Shitty cam imo.
Old Oct 2, 2008 | 07:11 PM
  #84
ColeJJones's Avatar
Bannned
http://tunersource.gmblogs.com/Racer...FO-SHEET-2.pdf
Old Oct 23, 2008 | 12:39 PM
  #85
el_angelito's Avatar
here ya go kids. the only thing that has changed is the cams, and the air temp/humidity. they are in std for this reason. SAE numbers are sorts of wacky. this is simply a cam stand off.
colors, cams, date that it was done. street numbers, not OMG dyno numbers.
red - gmr - 7/5/08
green - 272 - 2/10/08
blue - stock - 10/27/07
red was 11.6 afr. 20 degree's of timing
green was 12.0 afr 24 degree's.
blue was 12.4 25 degree's of timing.
im aware of the torque differences. there is a reason behind it. timing has a part of it, but the bigger part of it is compression ratio.
sorry bro but waht cam do you use.sorry but i dont understand can you explain me. sorry and nice work
Old Oct 23, 2008 | 12:43 PM
  #86
Omega_5's Avatar
*slams head on desk*
The chart you quoted is a comparison of 3 different cams, the stock cams, HKS 272 regrinds, and GM Racing cams.
Also, listed below the chart, is the AFR and timing associated with each dyno run.
Try not to compare the actual power listed on the chart, but rather the shape of the power and torque curves and how the power is delivered.
Old Nov 23, 2008 | 02:40 PM
  #87
brandon2.2's Avatar
I looked through the sticky in the 2.2 section, about L61 and LSJ swappable parts, it lists the exhaust cams between the two not being interchangeable.
but read this
http://www.crateenginedepot.com/store/PDFS/ECS.pdf
it states that...well hell let me paste it in here....
The 2006MY L61 cams can interchange with LSJ cams, both intake and exhaust. These cams are
the exact same profile, only at different timings. The 2006MY L61 timings are 116 intake, -103
exhaust. The LSJ timings are 100 intake, -115 exhaust
the reason I ask is because I was wandering about the Comp cams "blower grind" for the 2.2
Last edited by brandon2.2; Nov 23, 2008 at 02:40 PM. Reason: Automerged Doublepost
Old Nov 30, 2008 | 11:21 PM
  #88
o3nisoaso3's Avatar
but read this
wes "wsfrazier" and al "witt" knows about the cams, one of them may be able to help
Old Dec 24, 2008 | 02:01 PM
  #89
Zooomer's Avatar
Supporting Vendor
Excellent job of doing some research for the community. My only issue is that the comparison was not kept consistent. The AF ratio changed and as we know, these cars make more power as they get leaner. Timing was not the same and that greatly affects HP past 6k rpm.
Also, power adder and blower pulley size were not given. If the blower pulley is too small, it's going to be a limitation and skew the numbers on all runs. The variables should be eliminated. Same AF on all runs, same timing, larger blower pulley. Then we could see a true difference. I'm actually kind of suprised that the differences between the cams are so small, it's strange.
In our findings on the dyno, with a stock cam and car with exhaust, it's easy to make power keep climbing well past 7k with modifications to the PCM. These charts are showing fall off after 6500 and I think it would be a false conclusion if one were to think that it's a limitation of the cam or head.
Old Dec 24, 2008 | 02:22 PM
  #90
Area47's Avatar
Rent me! per hour
all runs were done with a 2.7.
with the meth mix i run. leaner does not make more power. the timing was varied due to either weather, or personal choice.
Old Dec 30, 2008 | 03:26 AM
  #91
Greased's Avatar
are you on the lean side of rich best torque?
Old Dec 30, 2008 | 02:02 PM
  #92
Area47's Avatar
Rent me! per hour
we all have our secrets, and the answer lies in my maf scaling filing
Old Dec 31, 2008 | 06:45 PM
  #93
qwikredline's Avatar
the shadow knows......
Old Jan 27, 2009 | 11:47 PM
  #94
rico's Avatar
so whats a good place or link to get gmr cams?
Old Jan 28, 2009 | 10:27 AM
  #95
ItalianJoe1's Avatar
GM probably doesn't have them anymore, but they had over 10 sets that all sold, and so far I know of only 3 people that actually used them. Best bet is to find a used set (there are at least 2 sets that have come back out of cars I know of), or find someone who bought them and never used them that would sell them.
Old Jan 28, 2009 | 12:49 PM
  #96
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
Old Jan 28, 2009 | 06:30 PM
  #97
rico's Avatar
damn that sucks i really wanted some i guess ill have to go with 272s and get the other things ill need to install them
Old Jan 28, 2009 | 07:44 PM
  #98
I may be able to get you a set, used for a couple miles but otherwise perfect. PM me an offer.
Originally Posted by Corvettespirit
I forgot about you
Make that 4 people I know of.
I also know two other people locally that have a set but haven't used them as far as I know. And one in Texas I think. So that's 7 sets I can account for
Last edited by ItalianJoe1; Jan 28, 2009 at 07:44 PM. Reason: Automerged Doublepost
Old Jan 28, 2009 | 11:52 PM
  #99
ColeJJones's Avatar
Bannned
same one you gave to Angelo to throw on my car?? not sure wtf you told him that night but i had a jeckl and hyde car after the tune
Old Jan 29, 2009 | 12:54 PM
  #100
Area47's Avatar
Rent me! per hour
perhaps
