cam comparison
Old Jan 29, 2009 | 03:35 PM
  #101
Doc's Avatar
Doc
I have a set of the GMR cams still in the sleeves.
Old Jan 29, 2009 | 03:42 PM
  #102
ShortStack's Avatar
I see these cams ground for Turbo applications on TTR...
Does this do anything? my guess would be a longer exhaust duration or something to help spool faster.. but... thats just a guess...
Old Jan 29, 2009 | 05:15 PM
  #103
Area47's Avatar
Rent me! per hour
no one makes cams for the lsj. gm racing had them ground by comp in tn from blanks, then they had the hex key pressed in. if you want cams, you have to take your stockers and have them ground to the specs you want.
Old Jan 29, 2009 | 05:19 PM
  #104
ShortStack's Avatar
Coulda swore i saw it said 2.0 but i went back and checked i was wrong..
thanks area..
Well.. either way... would a longer exhaust duration do anything to turbo spool?
Old Feb 4, 2009 | 12:46 PM
  #105
cmarler14's Avatar
ok i just got my cobalt ss s/c last may and i have the 3.0 pulley on it and a straight pipe exaust. What does everyone recomend to do to these cars ? Im just curious because this is my first supercharger and im still learning with these.. IM wanting to put #60lb injectors and prolly hp tunners with a tune on it.. or should i finish my exaust all the way out first? anyone up to help me out here thanks guys!!!
Old Jun 22, 2009 | 01:16 AM
  #106
redlineblueline's Avatar
maybe i am missing it but I am assuming the lines that peak furtherest left are torque and the other ones are HP or am I way off
Old Jun 22, 2009 | 01:21 AM
  #107
Area47's Avatar
Rent me! per hour
yepo
Old Jun 22, 2009 | 01:34 AM
  #108
so looking at that the stockers make the best power up to 5250 and then all the others make more and fall off less and you really dont make power past 6500 with the stockers or 272s
Old Jun 27, 2009 | 10:40 AM
  #109
Old Jun 28, 2009 | 10:49 AM
  #110
StreetDreamz's Avatar
Why are you bumping this thread? It has already been shown that the testing was too inconsitent to be of any value to use. Timing changes as much as 5 degrees and AFR as much as a full point richer. It's too many variables being changed to show a TRUE comparison. The fact that the stock cams beagn to fall off in this test before any other stock cam dyno means something is seriously wrong here.
Old Jun 28, 2009 | 01:16 PM
  #111
Area47's Avatar
Rent me! per hour
you are seriously a ******* moron.
STOCK M62.
Old Jun 30, 2009 | 05:39 PM
  #112
so whats your spin on what i said a few posts up area?
Old Aug 9, 2009 | 08:02 PM
  #113
harryresh's Avatar
why cant i find these cams on the internet? can anybody give me some links? im thinkin harrop tvs 1320 and cams
Old Aug 13, 2009 | 03:04 PM
  #114
ShortStack's Avatar
Because they do not produce em anymore to my knowledge, unless you get some type of custom grind...
Old Jul 9, 2010 | 10:05 AM
  #115
MrSlickSter06SS's Avatar
Who offers that?
Old Jul 9, 2010 | 11:58 AM
  #116
freakta's Avatar
i think you missed the point, he wasnt showng what would make the best hp, he played with the numbers to show the cam power curve for each. thats why each has diff a/f and all that jazz...
and the m62 is the problem with power not the cams, to a point
Old Apr 3, 2011 | 05:03 PM
  #117
BlackWidowSS07's Avatar
confused
Ok, so I starting looking into getting some 252 cams and i have read somethings on here that have left me confused.
Stock Cam + Adj Gears = Same power as after market cams?
What is a good cam to use to get to the 300 mark? I looked at the Comp Cams site and the highest I saw was 252's for the blower application.
Im trying to learn about internals here that I am going to start my build and do most of it myself minus the tuning
Old Apr 3, 2011 | 09:46 PM
  #118
Area47's Avatar
Rent me! per hour
the info on the cams in this thread are more or less out dated. the gmr cams with solid lifters will produce great numbers. for simple drop in cams. zzp has them.
cam gears move the power band around.
Old Apr 29, 2011 | 11:21 AM
  #119
RooTBeeR's Avatar
good info even if it is outdated
Old Jun 9, 2011 | 08:22 PM
  #120
microgab's Avatar
I've been trying to find info on the ZZP cams
Cobalt & Ion ---> ZZ Performance
Anyone have then? Worth the price?
Old Jun 12, 2011 | 02:13 PM
  #121
microgab's Avatar
Bump...anyone tried them?
Old Feb 27, 2012 | 10:40 AM
  #122
tbellazzi's Avatar
i'm looking at the zzp cams as well...anyone have any info on them...?
Old Aug 28, 2012 | 10:28 AM
  #123
eddi's Avatar
No CPS.
If I were to buy blanks and have them ground, but didn't have te CPS hex pressed in and ran without it, what kind of havoc could be done? Not willing to unplug and find out.
Old Nov 6, 2012 | 03:08 PM
  #124
05ssLSJT's Avatar
has anyone installed Turbo cams on the m62?
Old Nov 6, 2012 | 03:18 PM
  #125
where to get gmr cams...
