cam comparison
I see these cams ground for Turbo applications on TTR...
Does this do anything? my guess would be a longer exhaust duration or something to help spool faster.. but... thats just a guess...
Rent me! per hour
no one makes cams for the lsj. gm racing had them ground by comp in tn from blanks, then they had the hex key pressed in. if you want cams, you have to take your stockers and have them ground to the specs you want.
ok i just got my cobalt ss s/c last may and i have the 3.0 pulley on it and a straight pipe exaust. What does everyone recomend to do to these cars ? Im just curious because this is my first supercharger and im still learning with these.. IM wanting to put #60lb injectors and prolly hp tunners with a tune on it.. or should i finish my exaust all the way out first? anyone up to help me out here thanks guys!!!
so looking at that the stockers make the best power up to 5250 and then all the others make more and fall off less and you really dont make power past 6500 with the stockers or 272s
Why are you bumping this thread? It has already been shown that the testing was too inconsitent to be of any value to use. Timing changes as much as 5 degrees and AFR as much as a full point richer. It's too many variables being changed to show a TRUE comparison. The fact that the stock cams beagn to fall off in this test before any other stock cam dyno means something is seriously wrong here.
Rent me! per hour
STOCK M62.
and the m62 is the problem with power not the cams, to a point
confused
Ok, so I starting looking into getting some 252 cams and i have read somethings on here that have left me confused.
Stock Cam + Adj Gears = Same power as after market cams?
What is a good cam to use to get to the 300 mark? I looked at the Comp Cams site and the highest I saw was 252's for the blower application.
Im trying to learn about internals here that I am going to start my build and do most of it myself minus the tuning
Rent me! per hour
the info on the cams in this thread are more or less out dated. the gmr cams with solid lifters will produce great numbers. for simple drop in cams. zzp has them.
cam gears move the power band around.
I've been trying to find info on the ZZP cams
Cobalt & Ion ---> ZZ Performance
Anyone have then? Worth the price?
