Cam gear question....simple one!
Old Jul 11, 2009 | 09:14 PM
cobaltguy889's Avatar
Are the cam sprocket/gears the same between the 2.0 and 2.2? The "key" where you bolt it in to the cam stripped, and i need to get a new gear. A local member has a spare set off of a 2.2l that he was going to give me but i'm not sure if they are the same or not.
Anybody?
Old Jul 11, 2009 | 09:16 PM
damien's Avatar
How the hell did you strip that?
and no they are different
Old Jul 11, 2009 | 09:21 PM
long story...i had the timing chain on and the timing case, and went to put the crank bolt in to hold the belt pulley at the bottom of the motor, and when i was torquing it the chain moved a little... well it turned the cam gears because I forgot to TORQUE THEM WHEN I WAS DONE! the intake gear was ok, it was just the exhaust gear that got f'd...
I kept them snug because they are tq to yield and once you torque them you can't go back, so i wanted to make sure everything else was perfect before i tq'd them.....whew... lol....
Old Jul 11, 2009 | 09:22 PM
damien's Avatar
You coulda have put some tq, they call for 80+ftlbs!!!
Old Jul 11, 2009 | 09:23 PM
NWAE Cobalt's Avatar
check gm parts direct as far as the part goes, but i do believe they are the same
Old Jul 11, 2009 | 09:32 PM
ralliartist's Avatar
they are the same.
Old Jul 12, 2009 | 02:21 AM
well if they are the same then i'll just use the one that i can get from my buddy. I won't bother ordering one then.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
