Cam Shaft Pos Sensor
Twice I got the Code for Cam Shaft Position Sensor (P0341)
Once I reset it, and it didnt come back till the second time (2 months later)
Second time, it showed up on my interceptor, but when I hooked up my
Scan Tool to get freeze frame, it was gone....
Is this something I should be concerned with?
As of right now, everything seems to be running well.
Mine didnt show a code at firdt but the car was startig to take forever to start. Then it wouldnt start. Push-started it and went right to the store to scan the code that popped up... Cam posi sensor... 30 dollhair sensor. Its a pain to get to and replace but i got it done. Its on the rear drivers side of the block, iirc right behind a metallic coolant hose.
ballin on the budget!!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
