Cammed Cobalt
Old May 6, 2008 | 11:07 PM
  #51
shsballa023's Avatar
Please dont flame me when i ask this lol (yes im a noob with modding!) But do cams require tunning?
  #52
stage2's Avatar
sounds bad azz
any vid reving the engine a bit?>
Old May 6, 2008 | 11:08 PM
  #53
EdCobaltSS's Avatar
only if u want it to run correctly, and without stalling
Originally Posted by stage2
sounds bad azz
2morro
  #54
Ya i kinda figured, i just ask to make sure. Thanks man, and it sounds mean!
Old May 6, 2008 | 11:14 PM
  #55
xCobalt05x's Avatar
the stage 1 cams dont rquire any tuning but is recomended for best resualts. all the others require tuning
Old May 6, 2008 | 11:18 PM
  #56
EdCobaltSS's Avatar
yeah, factory cams are 232, stage 1 are 238, and stage 2 are i think 250, mine are 272
Old May 6, 2008 | 11:44 PM
  #57
xCobalt05x's Avatar
damn, you got the stage 3's.... the turbo grind are close to the stage one grind, more in between stage 1 and 2
here are the specs on the comp cams
-Street (Stage 1) Applications power from 2600-6800rpm .423 intake and .419 exhaust valve lift, 252 intake and 256 exhaust duration advertized (210 intake and 212 exhaust @ .050" duration) Works best with computer modifications not required.
- Street & Strip (Stage 2) Applications power from 3000-7500rpm .440 intake and .436 exhaust valve lift, 258 intake and 262 exhaust duration advertized (216 intake and 218 exhaust @ .050" duration) Requires computer modifications
-Street & Strip high RPM (Stage 3) Applications power from 3500-8000rpm .456 intake and .453 exhaust lift, 264 intake and 268 exhaust duration advertized (222 intake and 224 exhaust @ .050" duration) Requires computer modification very strong power over 5000 RPM
-Turbo Applications power from 2200-7000rpm .423 intake and .419 exhaust valve lift, 248 intake and 244 exhaust duration advertized (204 intake and 200 exhaust @ .050" duration) Wide power range, good power.
-Blower Applications power from 2800-7000rpm .423 intake and .436 exhaust valve lift, 252 intake and 262 exhaust duration advertized (210 intake and 218 exhaust @ .050" duration)
Old May 6, 2008 | 11:53 PM
  #58
rockkrawler628's Avatar
okay.... so i'd hafta tune for stage2 cams? wtf.. im pissed... I got the GM stage 3.. and they say i can upgrade pistons and valves and to a GM racing balance shaft and be good for up to 8,000 but i can't get it cam'd cuz the PCM is locked... wtf now im pissed
Old May 6, 2008 | 11:56 PM
  #59
xCobalt05x's Avatar
locked?! how that happen
Old May 6, 2008 | 11:59 PM
  #60
GM stage 3 ECU is locked directly from GM so it can't be changed... HPtuners never found out how to lock it and idk if it'll ever be possible
it has the rev adjuster up to 8,000 rpms but i can't go that high unless i get supporting mods... and w/ supporting mods i'd wanna get cams
Last edited by rockkrawler628; May 6, 2008 at 11:59 PM. Reason: Automerged Doublepost
  #61
xCobalt05x's Avatar
but GM said that the stage 3 is fully programable and is able to control a nitrous set up and that is what voids the warrenty when you install the stage 3
Old May 7, 2008 | 12:48 AM
  #62
racehtecobalt's Avatar
how much where the cams and where did u get them
Old May 7, 2008 | 10:58 AM
  #63
Area47's Avatar
Rent me! per hour
idle surging eh?
needs more timing control
Old May 7, 2008 | 11:25 AM
  #64
Sunburst_SS's Avatar
Originally Posted by Area47
idle surging eh?
Well, I changed a couple of the "special" tables.....it stopped it from stalling now, had some idle surge still.....I may try and advance the base idle timing a little more and see how that goes.....and raise the idle speed a tad.
Old May 7, 2008 | 11:58 AM
  #65
ralliartist's Avatar
those comp cams won't fit the 2.0 huh?
Old May 7, 2008 | 12:01 PM
  #66
Witt's Avatar
I found the best solution is to have as much idle adaptive timing as possible now and raise coast down spark. Also make sure the MAF calibration is spot on in the lowest few cells.
They "fit". You have to modifiy the last cam bearing surface and run them without a cam sensor.
Old May 7, 2008 | 01:23 PM
  #67
xCobalt05x's Avatar
465 was the cost
Old May 7, 2008 | 01:42 PM
  #68
Area47's Avatar
Rent me! per hour
Old May 7, 2008 | 05:19 PM
  #69
Blown 4-banger's Avatar
Sounds nice. Seeing as I will not be able to hide my cams, I figure I will make them even more apparent. My goal is to have people say "whats wrong with your car?" when they hear it idle
Old May 7, 2008 | 05:25 PM
  #70
WSFrazier's Avatar
Sounds like the LSJ I just finished, not bad. Needs a smaller pulley IMO.
Old May 7, 2008 | 05:26 PM
  #71
Raven SS's Avatar
hiding cams is FTL!! im with cam im making mine noticable as hell lol
Old May 7, 2008 | 05:27 PM
  #72
Area47's Avatar
Rent me! per hour
pointless untill lash adjusters "adjust"
Old May 7, 2008 | 05:30 PM
  #73
WSFrazier's Avatar
Maybe we already found a way to shim them right with the guys machine shop out there
2.6/meth/272 pulls pretty fkn good compared to Als 2.8 and my 2.5 setup.
Old May 7, 2008 | 05:39 PM
  #74
fballman1987's Avatar
i want to hear this when i get home from work...
  #75
Area47's Avatar
Rent me! per hour
you have a pm mr man
