Cammed Cobalt
damn, you got the stage 3's.... the turbo grind are close to the stage one grind, more in between stage 1 and 2
here are the specs on the comp cams
-Street (Stage 1) Applications power from 2600-6800rpm .423 intake and .419 exhaust valve lift, 252 intake and 256 exhaust duration advertized (210 intake and 212 exhaust @ .050" duration) Works best with computer modifications not required.
- Street & Strip (Stage 2) Applications power from 3000-7500rpm .440 intake and .436 exhaust valve lift, 258 intake and 262 exhaust duration advertized (216 intake and 218 exhaust @ .050" duration) Requires computer modifications
-Street & Strip high RPM (Stage 3) Applications power from 3500-8000rpm .456 intake and .453 exhaust lift, 264 intake and 268 exhaust duration advertized (222 intake and 224 exhaust @ .050" duration) Requires computer modification very strong power over 5000 RPM
-Turbo Applications power from 2200-7000rpm .423 intake and .419 exhaust valve lift, 248 intake and 244 exhaust duration advertized (204 intake and 200 exhaust @ .050" duration) Wide power range, good power.
-Blower Applications power from 2800-7000rpm .423 intake and .436 exhaust valve lift, 252 intake and 262 exhaust duration advertized (210 intake and 218 exhaust @ .050" duration)
okay.... so i'd hafta tune for stage2 cams? wtf.. im pissed... I got the GM stage 3.. and they say i can upgrade pistons and valves and to a GM racing balance shaft and be good for up to 8,000 but i can't get it cam'd cuz the PCM is locked... wtf now im pissed
GM stage 3 ECU is locked directly from GM so it can't be changed... HPtuners never found out how to lock it and idk if it'll ever be possible
it has the rev adjuster up to 8,000 rpms but i can't go that high unless i get supporting mods... and w/ supporting mods i'd wanna get cams
Last edited by rockkrawler628; May 6, 2008 at 11:59 PM. Reason: Automerged Doublepost
Well, I changed a couple of the "special" tables.....it stopped it from stalling now, had some idle surge still.....I may try and advance the base idle timing a little more and see how that goes.....and raise the idle speed a tad.
They "fit". You have to modifiy the last cam bearing surface and run them without a cam sensor.
