Cams
Old Jan 24, 2014 | 02:48 PM
06ssSuperCo's Avatar
Cams
Sugguestions on certian camshaft or brand i should get for my 06 ss sc?
Old Jan 24, 2014 | 02:50 PM
search... theres lots of decent info on here
most will suggest zzp stg2 or a custom comp cam. zzps cams are essentially modified comp camps
dannysauer's Avatar
Zzp sells some they r from comp cams heard good things about them also Ottp just started to carry some not sure if anyone has used them yet
Old Jan 24, 2014 | 03:58 PM
mrbelvedere's Avatar
zzp blower cams are ok but if you want a better choice either go custom or go ottp custom cams are a lot more involved and a lot more work
Old Jan 26, 2014 | 10:40 PM
I plan on getting these http://shop.zzperformance.com/store/...ance-Cams.aspx
Old Jan 26, 2014 | 10:41 PM
Now not sure if i should just get the stage 1 cams, or stage 2. My balt is tuned on e85, on a 2.7" pulley and 80# injectors
Old Jan 27, 2014 | 07:34 AM
Staged07SS's Avatar
Administrator
Administrator
I run the S1 cams, no regrets.
All depends on how much you want to get outta the car.
My S1 cams make peak power around 7250 rpm. S2 cams make peak power around 7500 rpm.
Not really modified, just degreed for easy drop in and go cams.
Old Jan 27, 2014 | 08:15 AM
OTTP LSJ Cams
Old Jan 27, 2014 | 08:33 AM
Tjolley's Avatar
Originally Posted by mrbelvedere
Wow ottp has a Nice selection. The s4 r tempting
Old Jan 27, 2014 | 08:45 AM
its pretty much what I am running
Old Jan 27, 2014 | 02:20 PM
dannysauer's Avatar
Mr B what else would u need to run the Ottp cams or what would u recommend to run with them
Old Jan 27, 2014 | 02:23 PM
ThexGovenor's Avatar
https://www.cobaltss.net/forums/2-0l...erence-299641/
you're welcome.
Old Jan 27, 2014 | 02:41 PM
Hockeyman's Avatar
ZZP/Comp S2 cams here. They feel great. May get mrB grinds in the future though.
Old Jan 27, 2014 | 03:42 PM
so you don't gotta replace cam bearing caps or anything dropping the zzp cams in right
Old Jan 27, 2014 | 04:20 PM
JapEatr's Avatar
South Central *********
just valvesprings and retainers
Old Jan 27, 2014 | 07:33 PM
I would talk to them and see exactly how they are setting up their cams they may be drop in and tune but if I were to run them a good set of springs such as 94lb supertech and a set adj cam gears
we do not use cam bearings spring it and tune it
Old Jan 27, 2014 | 08:14 PM
TStone's Avatar
I don't even think anyone has ordered OTTP's cams.... OTTP doesn't even have pictures of them or anything. They aren't even claiming they've tried them in cars.. soo....
ZZP's for easiness & most people.
Customs if you wanna go big.
Old Jan 27, 2014 | 10:02 PM
oh boy pictures are not needed and they the claims will come
Old Jan 27, 2014 | 10:04 PM
yellowss7590's Avatar
if hes getting cams he might as well do the springs... just sayinnnn.
Old Jan 27, 2014 | 10:07 PM
that's been covered just sayinnnn
Old Jan 27, 2014 | 10:09 PM
TStone's Avatar
Claims will come when someone actually takes the risk of buying them. Until then,, no one knows if they're good, bad, great, or hell, if they even exist!
Old Jan 27, 2014 | 10:11 PM
i think spddmn bought some
Old Jan 27, 2014 | 10:18 PM
okkk! just trying to help. lol
Old Jan 27, 2014 | 10:25 PM
TStone's Avatar
He got GMR's and solids
Old Jan 27, 2014 | 10:32 PM
the cams are there and they will be solid performers you should take some of your own advice
