cams
Old May 1, 2007 | 01:32 PM
sleepercobaltsc's Avatar
cams
http://www.smgmotoring.com/products/182/4
Does anyone know if these cams would work for the ss/sc? i want some cams really bad, but it sounds like everyone is having trouble with the JBP cams and the ones from Crate Engine Depot seem like they would just be a headache. i havnt heard of any other companies that make other cams either.
Old May 1, 2007 | 02:08 PM
alaskacobalt's Avatar
I found a set a while back that is made specifically for the Cobalt. I think I have a bookmark at home, I'll post it here if I can find it. I can't remember though what Balt it's for. I know it would fit my 2.2L, but now that I have a 2.0L I haven't checked back.
Old May 3, 2007 | 01:24 PM
anyone else got any thoughts?
Old May 3, 2007 | 01:26 PM
Witt's Avatar
They won't work. Your only choice for cams for a 2.0 at this time are reground stockers.
Old May 4, 2007 | 05:54 PM
http://www.gravanatuning.com/applica...ft_Set_Stage_3
these might be the same as the first link, but does anyone think these would work at all?
Old May 4, 2007 | 06:02 PM
Witt's Avatar
Same ones. Comp doesn't make any that will work with a 2.0. The ones stated from the LSJ build book were from blanks provided by GM performance division.
Old May 4, 2007 | 06:12 PM
Blown 4-banger's Avatar
Just get the sockers reground, they have a ton of material at the base (when the valve would be closed), so there is a lot of room to regrind. I'm getting mine reground.
Old May 4, 2007 | 06:31 PM
88cobaltSS's Avatar
I remember someone on here said they were getting their cams custom ground from crower for $150
Old May 4, 2007 | 06:32 PM
Witt's Avatar
The big cam companies will regrind your stockers for about 100-200 dollars to any spec you want. If you get too wild with them, you'll need shims for the lash adjusters, available from Bates Engineering.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
