View Poll Results: Which cams to go with?
OTTP Stage 3
13.33%
OTTP Stage 4
26.67%
Stage WTF? Custom grind
60.00%
Voters: 15. You may not vote on this poll
Which Cams to go with?
Old Mar 11, 2014 | 09:11 PM
Blairwolf's Avatar
I am looking for some input on which cams i should run. I am looking at getting a set of Josh's (OTTP) new cams. Thinking either the stage 3 or 4. Has anyone ran these cams yet? I asked Josh about stage 4 requiring adjustable cam gears and he said they weren't needed and that they should idle around 1000rpm. If you pick custom grind on my poll please let me know what grind you think i should go with.
Mod List-
Installed
Bolt-ons.
TVS, 2.8 pulley
Meth injection with 7gph nozzle
Going on soon
RSFS
LSJ-ion ported head
82# valve springs
ATI super damper
ZZP NBS
12gph meth nozzle
Since the ati damper is going to spin my blower pulley faster I may pulley up to keep the pulley size the same. I think a 2.7 without E85 may be a bit overkill. Lets hear everyone's opinions.
Old Mar 11, 2014 | 09:14 PM
BlackielawlessSS's Avatar
Go custom grind.
Old Mar 11, 2014 | 11:26 PM
mrbelvedere's Avatar
80% of the people on here are not smart enough to time the hex in the exh cam so don't go custom and you will need to check the cams centerline with a degree wheel and you will need adj cam gears if the cams are off
Old Mar 11, 2014 | 11:45 PM
Ss27gogeta's Avatar
i was talking to josh as well about custom cams to rev up to 9500-10k but went with stg 4 they will idle normal and will make power up to 8500 which should be good for the street
Old Mar 12, 2014 | 10:11 AM
Blairwolf's Avatar
The custom grind would be through OTTP. Josh would time the hex for me. I am interested in checking the cams with a degree wheel no matter what cams i choose just to make sure everything checks out.
Old Mar 12, 2014 | 10:13 AM
Blairwolf's Avatar
Awesome pick. Any idea when you will have them installed? What are your other mods?
Old Mar 12, 2014 | 12:17 PM
ok but if the cam is off of centerline then the hex will be off also
Old Mar 12, 2014 | 02:25 PM
Blairwolf's Avatar
I get what you are saying now.
Old Mar 15, 2014 | 08:29 PM
Blairwolf's Avatar
I'm most likely going with the stage 4 cams since they are drop in ready. Custom grind was just a thought. lol Just waiting to hear back from Josh about when he can get me a set.
Old Mar 17, 2014 | 01:41 PM
MrSlickSter06SS's Avatar
Good luck, I'm jealous hope it all works out for you, interested in the results you get when you are done.
Old Mar 17, 2014 | 01:49 PM
Spawne32's Avatar
i use ddtechcams.com for all my custom grinds, ill be using them in my 2.4 build as well
Old Mar 17, 2014 | 02:14 PM
good luck on that
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
