cant get belt off
you got to make sure it is all the way on and keep alot of pressure on it. just took mine off week and got frustrated but wants i got it you realize its easy
If it is rounded too bad you might have to hammer a 14mm down on it but that should be a last resort.
just put my back on with a 15mm wrench. imagine that. The trick is to use both hands and to PUSH DOWN more than you push over, once it bottoms out you can hold it with one hand and put the belt on with the other.
Exactly. Just be careful, use a bar to compress the tensioner, then stick an allen key in there to lock it down. You can then take your time with the belt, and it stays down until you put it back on.
