car bogs at high rpm
Old Aug 19, 2007 | 12:31 PM
powerz's Avatar
Does anyone have any idea what would cause my car to bog real bad at full throttle at high rpm (5500-7000) ?If I go threw the full rpm range at 80%throttle or less it does not do it at all.Just looking for a place to start checking . Also it started after I put in 104 racing fuel.and even though the fuel is now ran out its still doing it.
Old Aug 19, 2007 | 12:34 PM
Sales@rebelautoworxs's Avatar
Was the 104 fuel Leaded or not ?
If you used leaded fuel you killed your O2 sensors. They do not like leaded fuels at all.
One tank often is enough to kill the sensors.
Old Aug 19, 2007 | 12:37 PM
powerz's Avatar
I was thinking the same the place I bought it sells both but the boy who went and got my gas I would say needed help to tie his shoes each morning.besides the o2 sensor would it mess up anything else like say the injectors?
Old Aug 19, 2007 | 12:39 PM
braineater's Avatar
QFT!
Old Aug 19, 2007 | 01:07 PM
Maxim_X's Avatar
Your blowing out your plugs. Get new plugs, I suggest NGK BKR7E copper. They are like 2.50 a pop. Mine are gapped to .35.
Old Aug 19, 2007 | 01:10 PM
Element2.4's Avatar
I thought running leaded fuel can ruin your cats also? But as the other person said check your spark plugs.
Old Aug 19, 2007 | 01:15 PM
powerz's Avatar
I am running NGK BKR7IEX-11 1 step colder plugs got about 15000 miles on them when i checked them this morning they were alot blacker then normal I just cleaned them .
Old Aug 19, 2007 | 02:00 PM
M88ArRamadi's Avatar
leaded fuel will clog your injectors....check to make sure what type of fuel he gave you
Old Aug 19, 2007 | 08:00 PM
Maxim_X's Avatar
Did you re-gap them properly?
roadrunner132
Sep 19, 2015 04:35 PM
bucks121
Sep 12, 2015 07:39 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
Infamous SC/SS
Sep 4, 2015 05:33 PM
