Car Pulling to the right.
I am having an issue with the cobalt pulling to the right. I thought it was alignment so I took it to a trustworthy alignment guy, he found nothing at all.... told me to change the tire (nitto 555 wasted inside).. so I bought a new Nitto 555 and put it on. he balanced it for me and redid the alignement..... problem still stands.... he checked the struts, axles (which I told him I had stage 1 axles not even a year old). Everything checked out fine, mechanic says he doesn't see anything wrong with the car, that it might be a transmission pull.
Now I am turning to the pros.... Anyone got any ideas????
Road camber? Bad CABs? Strut mount bearing seized? Do you experience memory steer? Like if you go around a turn say 30mph and let go of the wheel does it self center? Because it should. And a bad strut mount bearing will cause the car to pull.. Each time you hit a bump your car is going to go one way or the other and if your strut mount bearing is seized it is obviously going to move the wheel and not self-center it. There are so many imperfections in the road and I think most people overlook this problem on the Cobalt.. It is a very commonly replaced part.
Stock CABs in bad condition will throw off your caster, as will a bad strut mount bearing.
Did you try switching the front 2 wheels.. Switch the driver and passenger side with each-other?
That's about all I have.. If your toe is fine, it's obviously something else.. The only thing left is caster really.. Camber doesn't get out of whack TOO much, even when lowered.
The alignment guy said that it might have to do with the transmission... He says that maybe the transmission has a problem and makes the car pull to the right. Do any of u know or think that is possible??? And how would I check if it's true??? If not, what else can be the problem???
Thanks for the help guys really appreciate it.
LOL besides the fact that I burnt my finger for testing..... nope the are both kind of the same hotness.
I don't need to hold it to the left... it goes straight when u have it straight =)
Yeah... let's see what it can be...
Ok my mechanic read all of these posts and said that mostly it all had to do with aligning.... The car is aligned right... When ur driving and u hold the wheel straight the car goes straight... the problem is that the car pulls to the right when u let go of the steering wheel. Also I've noticed that the steering turns to the right about and inch or 2 but it just stays there... it doesn't keep turning.
Turbo Johnny
Feb 21, 2019 09:41 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
