Car won't Start!! Help!
Old Dec 18, 2008 | 12:52 AM
RauLiTo SS/SC's Avatar
Exclamation Car won't Start!! Help!
So, I installed 60's and a dual pass endplate. Also a stage 4 Pcm that I bought from a member in this site programed for 60's and a 2.6 pulley.
So I put everything on and when I tried to do a case learn, the car did not start. I dont have hp tuners nor i know anybody who has acces to it. So i took out the new pcm and put the old one back. And I tried to start it again but it does not start.
Is it possible that the car locked itself for the unknown pcm?? Or is there anything that i am missing.
When i turn the key, The fuel does not pass throght the injectors. Plus i added coolant bacause of the option b but the coolant does not go anywhere.
So is there anything that i need to do.. What and how could I sove this problem??
Please I totally need your help!!
thanks!!
Old Dec 18, 2008 | 10:03 AM
Bump for help...
Old Dec 18, 2008 | 10:07 AM
LS6Rally's Avatar
when you say teh fuel dosent pass through the injectors are you saying they dont spray??. check to see if your getting fuel pressure at the rail. also make sure that the clutch is all the way down. and whats your battery voltage
Old Dec 18, 2008 | 10:12 AM
Wolf117's Avatar
re connect the battery? jk, i dont know
Old Dec 18, 2008 | 10:50 AM
Bump for help!!!!!
it dosent spray and in te boost gauge stays at 0 theres fuel rail but theres no pressure
Last edited by RauLiTo SS/SC; Dec 18, 2008 at 10:50 AM. Reason: Automerged Doublepost
Old Dec 18, 2008 | 11:11 AM
light'bolt's Avatar
not sure but have you checked the fuse for the injectors??
Old Dec 18, 2008 | 11:47 AM
zipo1200's Avatar
Well so far it seems you guys have nailed the fuel problem. The pcm itself does a self check before you can even turn your key. When you turn your key, you should be able to here your pump pressuring up the fuel rail, Try with both pcm's. Also from my understanding is that the pcm has to have your VIN in its memory banks or it will not start. there may be another problem as well. Check your connections with the pcm and see if anything is unusual when you turn the key in the on position. We are going to need to know if that pump is turning on.
oh and drain the fuel out of the fuel rail with the check valve so the pump stays on longer so you can here it
Old Dec 18, 2008 | 12:48 PM
383_Stroker's Avatar
You didn't take the fuel pump relay out when you were working on it did you?
Old Dec 18, 2008 | 12:50 PM
BLAZIN07SS's Avatar
I'm too JDM for you
how careful were you with the harness pins on the ECU? they love to break apparently
Old Dec 18, 2008 | 12:51 PM
bwalker0510's Avatar
had this problem. didnt fully connect the 60 lb injector harness. i guess check that. mine felt like it was fully connected but i put a little more force behind it and it was fixed.
Old Dec 18, 2008 | 06:32 PM
From my understandig the Pcm doesnt have my vin in its memory. I checked the injector harness, and its good. I will have to check the vin PCM pins to check they arent broken .
Thanks!
Old Dec 18, 2008 | 06:51 PM
ptrblkz24's Avatar
+1.if u did,you probably put the relay back in the wrong spot.
Old Dec 18, 2008 | 10:10 PM
No I did not take the pump rely out
Old Dec 21, 2008 | 08:47 PM
cobalt ss/sc's Avatar
can you hear ur fuel pump working?
Old Dec 23, 2008 | 01:08 AM
rukkee's Avatar
Did you pull the fuse for the fuel pump when changing injector's? It's really easy to put it in the wrong slot when putting it back in, triple check that it's in the right spot.
This happened to me and it looked fine but was off one socket......took me a while to find the problem and i was pissed when i realized what i'd done. It's happened to a bunch of people so it's a pretty common oversight.
Old Dec 23, 2008 | 01:15 AM
JimzSS's Avatar
I believe you are close with the vin # not registering.
put the old pcm in and try it...if you still haave it.
As mentioned many times on this site, the pcm's are vin sensative...lol
Turbo Johnny
Feb 21, 2019 09:41 AM
How to Guide
57
Oct 15, 2015 11:56 AM
hawkssoccer11
Sep 30, 2015 12:14 PM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
